synthetic ATF worth it?
Old Aug 12, 2006 | 07:15 PM
nmbis2k's Avatar
nmbis2k
Default synthetic ATF worth it?
I am ready to have the full fluid change on my 2000 A4 coupe.
Is the synthetic ATF worth it?
Does GM make/sell that...what is it called?
What T-IV?
thanks for your inputs.
Old Aug 12, 2006 | 07:30 PM
patton's Avatar
patton
St. Jude Donor '09
this is my opine if over 50000 miles dont service it its too late if under youre doing good. i may be wrong but i dont think the trans calls for syn fluid. look at owners man. or go to dealer and buy gm fluid. by the way the service if youre gonna do it has a procedure ya have to follow its no easy good luck
Old Aug 12, 2006 | 09:50 PM
nmbis2k's Avatar
nmbis2k
22,000 now.... and trans pan dropped at 18,000 and new filter installed along with a aux. B&M flat plate trans cooler.
Old Aug 12, 2006 | 10:54 PM
patton's Avatar
patton
St. Jude Donor '09
and youre gonna do it again
Old Aug 12, 2006 | 11:07 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
It sure makes the shifting alot smoother.
Old Aug 13, 2006 | 08:12 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Yes
Peace
Willfulone
__________________
..................Click for
Old Aug 13, 2006 | 08:36 AM
David426's Avatar
David426
Some people swear by the Synthetic ATF and others say stay away. I have read magazine articles and read posts from several others on Synthetic ATF glazing the Clutch Paks on the 4l60e causing excessive slippage. This is a highly debated subject. My Transmission went out at 38000 miles shortly after a change to Synthetic ATF. Was it the Synthetic ATF?? Anyhow,, just wanted to make you aware that this is a highly debated subject and lots of folks use the sythetics with no problems, so you can make your own descision .. Good Luck... Here is another Synthetic ATF link.. Do a search and you will find more http://forums.corvetteforum.com/show...=synthetic+atf
Old Aug 13, 2006 | 09:20 AM
cenzo's Avatar
cenzo
Dexron VI. Have the DEALERSHIP do it.
Old Aug 13, 2006 | 03:09 PM
nmbis2k's Avatar
nmbis2k
thanks David and Censo ----- my coupe is not a race car....just a Grand Tourer. So....I'll likely go to a Chevy dealer and do Dextron VI with the flush and fill.
Just want that trans to live another six years!
BTW, the B&M flat plate cooler that Andy of A&A installed did lower the temp 20+ degrees. Yet to exceed 195, formerly saw 220 climbing into Sequoia Nat Park on a 100 degree summer day.
To synthetic ATF worth it?
