having trouble shifting!!!
Old Aug 12, 2006 | 08:46 PM
stlchevy97's Avatar
stlchevy97
Default having trouble shifting!!!
i have had a similar problem before where i couldnt get it in gear without grinding and turns out my master and slave went out and i needed a new clutch. so i got a brand new 26 spline mcleod clutch kit that better be good because it was 1400 dollars. and replaced the master and slave. after all that it drove great for a while. had to mash the clutch or it would grind. now i am having trouble throwing it into second above 5k rpm's without it grinding on me. seems like there is never ending tranny problems/clutch. anyone have this problem? any reccomendations would be appreciated. thanks
Old Aug 12, 2006 | 09:49 PM
Darkness's Avatar
Darkness
Sounds like your syncros are going out. That might be an expenssive fix too.
Old Aug 12, 2006 | 11:12 PM
stlchevy97's Avatar
stlchevy97
last time i took it to aamco to fix the slave/master/clutch. they said they had to fix the syncros as well. that was a very big bill that day.
To having trouble shifting!!!
