Delco Bose Question
Old Aug 14, 2006 | 10:55 AM
RedY2K's Avatar
RedY2K
Default Delco Bose Question
I just bought a 2000 vert. Previous owner had replaced the Delco Bose audio system with a cheap aftermarket system. I want to return to the OEM system, but I'm not sure that I have everything I need. I have the head unit with cassette player, the 12 CD changer, the door speakers with amps and the rear speakers. Do the rear speakers run off the door amps or do I need another amp or amps for them? Anything else?
Thanks.
Old Aug 14, 2006 | 05:18 PM
Robiwan's Avatar
Robiwan
No offense, but don't go back to the bose OEM system. Do yourself a favor and buy a good aftermarket system. Check out the audio/electronics under general forums on this website. If you really want to go back, you don't need another amp for rear speakers, but having all the wiring with the correct connectors to go into head and CD unit makes it much easier. don't do it, don't do it, don't do it.
Old Aug 14, 2006 | 05:57 PM
Warp Factor's Avatar
Warp Factor
That Bose system leaves a lot to be desired.
I think you'll be disappointed.
Old Aug 14, 2006 | 07:50 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks.
If you have mind set on installing "Bose" back in the rear speakers are not amplified only the sub-woofers in the front doors.
The BOSE speakers are cheap and made of paper instead of poly.
Like the others before me said you would be better off with an after market system. I don't know if you are into digital music (MP3's) but many of the after-market systems can play a CD full of these (about 120 songs) per CD.
Old Aug 14, 2006 | 09:54 PM
RedY2K's Avatar
RedY2K
Thanks, guys, but I'm a purist. I'm gonna go with the Bose.
Gary
Old Aug 14, 2006 | 10:50 PM
flexvette's Avatar
flexvette
Default Delco Bose
The biggest beef I've had with this system is radio. It seems that the antenna does not provide good reception, thus a poor sound. When you are playing CD's the sound quality is much better. Still, without a sub you leave a little pop on the table, vs an aftermarket system.
2003 QS Coupe
Old Aug 15, 2006 | 02:59 PM
bighank's Avatar
bighank
Default bose system
My C5 with the bose system has the BEST sounding FM radio and the WORST sounding AM radio I've ever owned in a car. CD and Cassette are OK Take ur pick.
Old Aug 15, 2006 | 03:23 PM
Jim2003's Avatar
Jim2003
I agree with you about being a purest. Put it back orginial.
The Bose system is fine with me. It is a small compartment and the sound is good as far as I am concerned. I never did like nor do I now like that thumping bass rattling everything in the car. That is just noise not good music sounds.
My wife and I travel in the vette so we use the CD alot. We take a selection of different types of music and we neither one complain about the Bose sound system.
I will get flamed for this view, but such is life.
Old Aug 16, 2006 | 02:04 AM
white90conv's Avatar
white90conv
Besides the head unit, there is also some kind of bose signal processor under the dash. It may still be there or maybe it was removed. You need that component to restore the bose system. I have the bose system in my car and consider it quite good on CD's. I never use the AM or FM radio for music.
Old Aug 16, 2006 | 07:37 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
2003 QS Coupe
you have a sub in each door.
all I did was change the front 3 1/2" speakers to a good quality coaxial and change the rear speakers to Infinity 505cs component speakers.
I also removed the 12 disk changer and installed Sirius satellite radio, so I don't listen to am/fm or CD's anymore.
Old Aug 16, 2006 | 07:40 AM
RPOZ4Z's Avatar
RPOZ4Z
you may want to look into satellite radio.
Old Aug 16, 2006 | 08:12 AM
Hatdude's Avatar
Hatdude
.. and *pay* for radio? Now something is absolutely wrong with that. Next they'll be selling water and air ... wait a second..
Old Aug 16, 2006 | 08:42 AM
RPOZ4Z's Avatar
RPOZ4Z
Old Aug 16, 2006 | 11:34 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Thanks.
Aaah........There couldn't be anything cheaper than the Bose system. Thet are just junk, plain and simple!
Old Aug 16, 2006 | 03:33 PM
Joe C5 C2's Avatar
Joe C5 C2
I used to say the same thing, "Pay for radio" ? I have had Sirius for two years now and would never go back, the selection is great. If you go this route do the direct input into the radio instead of the FM modulation, it is so much better.
Old Aug 16, 2006 | 06:29 PM
TheDarkKnight's Avatar
TheDarkKnight
Same here, except on the XM side. never understimate the power that lack of commercials brings you.
Long trips it's nice. But short trips I think it's better. I work 2 miles away by odometer. With FM if I catch it just wrong, I wind up hearing naught but commercials the whole trip. With XM, it's always music.
Old Aug 16, 2006 | 06:54 PM
EHS's Avatar
EHS
I used to do the audio upgrade thing when I was a teenager. Now I've grown up.
The Bose system is just fine, especially in a convertible. I have it, I know.
All these purists who are so into sound quality, yet they drive around in a car. You'll never eliminate the road, exhaust, and wind noise.
If you want the best sound, put it in your house, in your living room.
The car will never be ideal, and it's really not ideal with the top down at 80 mph.
The Bose is fine for that.
Old Aug 16, 2006 | 07:56 PM
Chuck01's Avatar
Chuck01
Am is terrible and static when I put windows up or down.
Old Aug 16, 2006 | 08:49 PM
good_times's Avatar
good_times
I have to agree with the purists, im 22 have a 04 blk Z06 and i think the stock bose is fine, my buddy who works at a local audio shop who's into all the aftermarket decks and speakers says the factory bose really isn't that bad. plus i don't want anymore weight added to my already heavy 3100 pound car.
To Delco Bose Question
