Code 704 Clutch switch. help
Old Aug 14, 2006 | 11:29 PM
MawneeC5's Avatar
MawneeC5
Default Code 704 Clutch switch. help
After installing my new clutch/master/slave I no longer have to push my pedal all the way to the floor to shift. Infact my clutch engagement is about an inch from the top of the pedal travel. The only problem with this is that I keep getting code 704 because I never push it all the way to the flor to hit the switch:
http://www.gearchatter.com/viewtopic9477.php
It seems the car watches how often you push the clutch while driving and tosses a code if you start/stop a certain number of times without hitting the switch.
Anyone else have any experience with this and discovered a work around ?
I do have a Mcloed Master, so I could adjust it down...but I really like the clutch engagement where it is.
Could I just jump out the switch all together ?
Thanks in advance for any advice
Old Aug 17, 2006 | 12:54 AM
MawneeC5's Avatar
MawneeC5
Anyone ?
