Replaced the oil pressure sensor, Again! Pics!
Oh, and I should add I used the recommended torque of 15 ft-lbs to be accurate. I'm hoping this one lasts longer. If it fails, I'll have to throw out some more $$ to buy a different brand instead.
And yes, it was lots more fun the 2nd time around!! I'm getting good and fast at this too.
For those interested, I took a pic of that weany vacuum tube (i.e. straw) in the back that always is a pain to get it to fit into that tiny rubber elbow in the back of the manifold. I took the advice of some others to buy the 1/4 in tubing and a vacutite kit to extend it's reach to easily stick it into the elbow before moving the manifold back into place. Made the install much easier for certain.
Here's a nice step by step w/ pics link for those in need:
http://forums.corvetteforum.com/showthread.php?t=958008
Enjoy!
Here's a nice shot w/o the intake manifold:
This pic demonstrates the vacuum tube "mod" which can otherwise make this job quite painful. I tried but couldn't get the elbow off the manifold either. So this addition of the the rubber tubing to the plastic "straw" really was quite helpful. Hope this helps others.
Here's the new sensor. I should have taken a pic of the defective one, but I forgot
Basically it had oil inside the area where the connector wire harness would go.
Lastly, here is a possible explanation for the quality issue w/ this part
I try to look at the bright side.. At least the oil dipstick is not underneath the intake manifold too
GM is either has the dumbest engineers on their design team or the smartest...
I say the latter.. Their directive was to design in the longest and most expensive repairs for the simplest of issues.
They know the Corvette is a High Performance Sports car and the average idiot with $50K to blow is not going to balk at repair prices when something breaks
Where do I start?
Plastic Head light Gears - Could be made of Cheap Pot metal and would last longer
Clutch Bleeder burried inside the torque tube - Remotely located could eliminate 90% of Dealer fix
Oil Pressure Sensor High failure rate and UNDER the Intake Manifold - Easily accessible could eliminate 90% of Dealer fix.
There are three... Anyone feel free to add anymore?
should i continue on?? haahahah needless to say my car has been dissasembled and reassembled countless times now..
Charlie
Oil Pressure Sensor High failure rate and UNDER the Intake Manifold - Easily accessible could eliminate 90% of Dealer fix....
Charlie
Charlie
exactly.. 6 of one 1/2 dozen of another.. Bottom line, is it's still On top of the motor in an inaccessible place..
Charlie
You have a forum member looking for advice on how to replace the thing, and you can't even tell him where he needs to look.
Thanks for the advice.
BTW -- you don't need to remove the intake manifold to replace it. This has been posted before. Take a look.
Charlie
Where do I start?
Yeah there are a lot more, but I recently got flamed for bring them up. I am very dissapointed in GM's quality and engineering. I was raised a GM brat. Dad worked at the Tech Center from 55 to 85 when he retired. Does that mean I don't like GM products no not at all but the pea poor quality and design explains why the car company I grew up on is fast falling and soon will be number 2 behind Toyota. It just to sad to believe. It is a compnay that for far to long has been run by the bean counters and not by car guys.
Looks Pro!
