Oil Consumption (Update)
Old Sep 7, 2001 | 05:43 PM
KevinVette's Avatar
KevinVette
Default Oil Consumption (Update)
As many of you know I have a new 2001 Vert MN6 with 3000 mi. It has been using oil at the rate of 500mi/qt. The dealer has documented this. It also smokes on accel.
The dealer wanted to make sure there wasn't something else wrong with the car, so I brought it to the dealer yesterday.
The dealer pulled all the plugs to check for oil and the PCV valve. Nothing wrong was found.
The dealer put in an order for the new rings. They will wait a few days then check the status. The dealer said the rings were difficult to get.
No mention of extending the warrenty, etc., since they feel GM is fixing the problem. He said this is the first Corvette they have had problems with.
The dealership probably sells 2-3 vettes per month.
I noticed others on the Z06 forum having their rings replaced. Also talk of a class action law suit. I also read there was a bad batch of LS1's.
Just when you think the statistics won't hit you. No column lock YET!
Another Problem:
Since the door lock was working when the car was in the shop, there was nothing they could do!:cuss I would have to wait until it totally failed.
Old Sep 7, 2001 | 05:57 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Oil Consumption (KevinVette)
hope it works out
Mark
Old Sep 7, 2001 | 06:49 PM
carpe dm's Avatar
carpe dm
Good luck! Tell them you want the new pistons too...... :yesnod:
Old Sep 7, 2001 | 07:00 PM
Krazyhorse
Default Re: Oil Consumption (carpe dm)
Hope you have a good experience and they resolve your problem :seeya
Old Sep 7, 2001 | 09:15 PM
Arkay's Avatar
Arkay
Good luck....I was told they will do NOTHING until the car has at least
10K miles. Your dealer can order all he wants but I question if the ring
replacement will be authorized on a low milage car
Old Sep 7, 2001 | 11:38 PM
KevinVette's Avatar
KevinVette
Default Re: Oil Consumption (Dick Kriss)
My dealer has been in touch with the regional manager who recommended rings.
I don't think they want to tell me to wait until 10K after telling me damage may occur over time from using this much oil.
By forcing me to wait would mean I would be past the lemon law period.
To Oil Consumption (Update)
