Engine Whistle Normal Or Not?
Old Aug 16, 2006 | 12:14 AM
CodeName Z06's Avatar
CodeName Z06
Default Engine Whistle Normal Or Not?
I just got a 02 Z with 27000mi, but when the engine idles i can hear a whistleing type of noise coming from the engine. When i accelerate the you cant hear it anymore, but when you let go and almost back to idle the nosie gets a bit louder, then back to a single tone. No codes or anything, just wanted to check if its normal, or not.
Old Aug 16, 2006 | 12:18 AM
SLPRC5's Avatar
SLPRC5
Any MODs done to the engine?
Old Aug 16, 2006 | 12:42 AM
CodeName Z06
Not that i know of.
Old Aug 16, 2006 | 11:08 AM
n2zo6stuff's Avatar
n2zo6stuff
That's funny because i just bought a 03 z06 with 26k miles an it does the same thing. I was wondering if it was in the drivetrain, maybe the clutch or the shifter. I'm a vette rookie so if my guesses sound silly, don't hate me.
Damon
Old Aug 16, 2006 | 01:15 PM
Uncle John's Avatar
Uncle John
I've heard somewhere that there is a passageway in the lower part of the LS6 intake manifold that can cause this. Don't have any other information about it though.
Old Aug 16, 2006 | 05:42 PM
BlueRag's Avatar
BlueRag
There is a TSB for this problem as it affects the 2001 C5. I had mine replaced under warranty. Do a search on the corvette action center website..
Old Aug 16, 2006 | 10:09 PM
CodeName Z06
Does it cause a problem or is it just a minor annoyance
Old Aug 16, 2006 | 10:46 PM
n2zo6stuff's Avatar
n2zo6stuff
With my car, it doesn't seem like a problem but i'm curious as to if the noise is a problem in the making?
Old Aug 17, 2006 | 04:56 AM
EHS's Avatar
EHS
Did you check the TSB? Is it a problem?
Old Aug 17, 2006 | 05:39 PM
bhazard1's Avatar
bhazard1
This is funny. I just installed an LS6 intake on my 98 and it whistles a bit driving at lower RPM's. I was also wondering what it is and if it's a problem. I don't get any codes and the car runs as normal.
Old Aug 17, 2006 | 11:45 PM
CodeName Z06
I did a search on z06vette.com and it seams to be some what normal since many people have it and no one sugested it caused any problems, i also read it gets worst when you install an air intake.
Until it causes a problem i am just going to have to live with it.
The cure is driveing at high rpms.
Old Aug 17, 2006 | 11:52 PM
bhazard1's Avatar
bhazard1
thanks for the info. I have the hurricane intake, it seems like you can really hear the air flow since I installed the ls6 intake manifold. I'd like to get rid of the whistling though, it's quite annoying.
Old Aug 18, 2006 | 12:49 PM
molson's Avatar
molson
There is a small cavity where the throttle body meets the intake that could be causing the whistling.
Many people fill it with epoxy to try and eliminate the noise.
BTW I have a '98 with the LS6 in take also
Old Aug 18, 2006 | 09:28 PM
bhazard1's Avatar
bhazard1
Thanks,
I'll have to try that.
Old Aug 19, 2006 | 06:38 AM
EHS's Avatar
EHS
Guys, guys, guys...........
Subject: Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 02-06-01-021
Models: 2001 Chevrolet Corvette with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Avalanche, Silverado, Sierra, Tahoe, Suburban, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL) with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)
Condition:
Some owners may comment on a whistle noise coming from either the intake manifold or the throttle body. The noise is most noticeable between 1100 and 2000 RPM.
Cause:
This condition may be the result of airflow through the intake manifold.
Correction:
Replace the intake manifold with the part listed below. Refer to the Intake Manifold Replacement procedure in the Engine Mechanical - 5.7L sub-section of the Service Manual (SI Document ID #642853).
Old Aug 19, 2006 | 06:57 AM
Ranger's Avatar
Ranger
Whistle is characteristic. Has no effect on the behavior or performance of the car. Both my 01 and 02 had a whister under certain conditions and both ran very well. J-Rod has a video posted of a 6600 launch, you can hear the whistle at idle.
Ranger
To Engine Whistle Normal Or Not?
