Firebird 3.8 head removal
Old Aug 16, 2006 | 08:24 PM
Scoundrl's Avatar
Scoundrl
Default Firebird 3.8 head removal
I know this is a C5 forum but I also know there are a lot of mechanics on here so I figure I'll ask. I have a girlfriend with a 96 Firebird with a 3.8 that has a blown head gasket. I like her enough to do the job but not enough to pay for it . I would like a step by step but would live with just some advise from someone who has done heads on a firbird with a 3.8 in situ.
Thanks guys!
-Ken
Old Aug 17, 2006 | 12:53 AM
geocor2003's Avatar
geocor2003
I also own a V6 Camaro & recently asked a mechanic how tuff it was to remove the heads.He said its possible but very difficult,& its almost better to remove the engine to make it easier.For more info go on www.firebirdv6.com/
Old Aug 17, 2006 | 07:37 PM
usd2sing's Avatar
usd2sing
its a no brainer.
same as any other car.
camaro/firebirdv6.com
or fullthrottlev6.com can be your friend
remove upper and lower intakes.
remove ex mani
remove rockers, pr's
remove head.
theres some more to do but its self explanitory(sp?).
just watch for the ground strap on the rear/back side of the dr side head.
if its never been done on the car it may still have the stock factory lifting brackets....the one on the pass side is a pita...remove it, dont put it back on.
send me your email and i'll copy u some info. pdf file..
today im starting on more mods on my kids 02 v6 maro. so i'll be pulling the heads, cam etc...
but i have it down to a science....can have the heads off in 75-90min..
good luck
peace,
Old Aug 17, 2006 | 08:20 PM
Scoundrl's Avatar
Scoundrl
You are the man! I suspected it could be done with the right tools pretty quickly. My email is forums at athometech.com. I hope to get this thing done soon so I can have my truck back!
Take care,
-Ken
Old Aug 17, 2006 | 08:23 PM
usd2sing's Avatar
usd2sing
file sent
btw. head and rocker arm bolts are tty (torque to yield). must replace!!! every time u pull them. unless u go to arp stud kits (heads) and comp cam reusable rocker bolts like we did..
good luck
Take care,
-Ken
Old Aug 18, 2006 | 10:31 AM
SpeedyZ's Avatar
SpeedyZ
The engines sits so far back up under the cowl in those Firebirds they are a real pain to work on. Real hard to get to anything on them. You might want to look around, it may be a lot easier to find another girlfriend.
Good luck
Old Aug 18, 2006 | 11:50 AM
usd2sing's Avatar
usd2sing
Good luck
its not that bad...typical fbody.
once u get the coil pack off you'll see..plenty of room to work.
no worse than spark plug 7 & 8 on our c5s.
Old Oct 26, 2011 | 08:10 PM
91firebird305's Avatar
91firebird305
2nd Gear
basically, you have to remove everything. hahahaha
Old Oct 26, 2011 | 08:12 PM
lucky131969's Avatar
lucky131969
Great job at posting on this 5 year old thread.
IBTL..................
To Firebird 3.8 head removal
