Headlight Noise
Old Aug 17, 2006 | 08:24 AM
Big Ron's Avatar
Big Ron
Default Headlight Noise
Has anyone had this problem. I have a 2003 Coupe, no problems ever. I got home last night & turned the engine off. After the headlights went down there was a grinding noise like the motor that operates the headlights continued to run and the gears were grinding. The lights worked fine this morning but when I parked the same thing happened. Since the headlights are going up and down the motor appears to be OK. Any idea what the problem might be?
Old Aug 17, 2006 | 09:42 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
here http://forums.corvetteforum.com/show...DIY&forum_id=1
Old Aug 17, 2006 | 01:21 PM
JC in XTC5's Avatar
JC in XTC5
Originally Posted by Big Ron
Has anyone had this problem?
Many.
Old Aug 25, 2006 | 09:06 AM
Damo97's Avatar
Damo97
Big Ron,
Did you try the gear replacement? Did this work? (Mine is doing the same thing as yours.)
To Headlight Noise
