Pcv Valve Where Is It How Do You Replace It?
Old Aug 17, 2006 | 02:05 PM
bighank's Avatar
bighank
Default Pcv Valve Where Is It How Do You Replace It?
Looking at the engine and the factory manuals I can's seem to find the PCV VALVE.
Located something on drivers side which I thought was the valve but it won' t budge.
How do you replace it?
Old Aug 17, 2006 | 02:47 PM
mfrejek's Avatar
mfrejek
I cannot speak to all C5s, but my pcv valve is on the drivers side, top, rear of the engine close to the firewall. It looks like an ordinary PCV valve (provided you know what a pcv valve looks like). I am also assuming that you have removed the rail cover on that side, otherwise it will be difficult to see.
Old Aug 17, 2006 | 06:30 PM
see5's Avatar
see5
Follow the line out of the rear of driver's side valve cover around back of engine. There is a bulge in the hose and it is in there.
Old Aug 17, 2006 | 07:08 PM
thorn92's Avatar
thorn92
http://forums.corvetteforum.com/show...ight=pcv+valve
Had the same problem...check here
Old Aug 17, 2006 | 07:22 PM
Blow Torch's Avatar
Blow Torch
Originally Posted by thorn92
Check this link. I'm not sure about one on the driver side, but 2000 and earlier have one on the passenger side as well. Had it off when I was doing my catch can.
Old Aug 17, 2006 | 08:02 PM
pawngod's Avatar
pawngod
my 97 has it across the rear of engine...but it is made on the hose and you have to replace the entire pc valve connection...not sold separately.......i just cleaned mine and put it back in......to replace it...it has several hoses made on it about 2 feet long goes from valve cover to valve cover ....its 70.00 buck for entire pcvalve system ...atleast it is on the 97
Old Aug 19, 2006 | 03:45 PM
bighank's Avatar
bighank
Default Pcv Valve
Thanks for the comments.
Found my C5 '98 PCV valve on the PASSENGERS SIDE on top if the valve covers in the bulge in the large hose running front to back.
Was very clean. Took it out and cleaned it with brake cleaner.
Good for another 5 yrs.
Why does GM move this part around so much?
Thought it was inside a large HARD PLASTIC round cover at the very rear of the drivers side valve cover. When I originally tried to remove this cover it looked like it would BREAK. What the heck is hidden underthis cover?
Old Aug 19, 2006 | 05:40 PM
pawngod's Avatar
pawngod
there is nothing under it...found out the hard way after taking it out...like to never got it back in!!! thats wierd ..cause my 97 shows on the fender well sticker, drivers side that my pvc should be same as yours..on the passenger side near valve cover...but it isnt...i found it behind intake close to firewall....wondering if its been changed out by previous owners???
Old Aug 19, 2006 | 06:03 PM
see5's Avatar
see5
04 on there is no vent on valve covers other than pass front into intake.
LS6 Valley cover vents into intake. No PCV valve.
You can plug yours and get LS6 valley and be way ahead.
Old Aug 19, 2006 | 07:10 PM
hotwheels57's Avatar
hotwheels57
I'm still learning, bear with me...so my '04 Z16 has no PCV?
Old Aug 19, 2006 | 07:38 PM
see5's Avatar
see5
Nope, check it out.
Old Aug 20, 2006 | 03:01 AM
VETSTYL's Avatar
VETSTYL
Default G Spot
Reading through theses postings, it seems the PCV is more elusive than the mythical "G Spot".
Old Apr 10, 2016 | 01:54 PM
Ron Reuben's Avatar
Ron Reuben
Cruising
whats a "G" spot ?
Old Apr 10, 2016 | 02:04 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by Ron Reuben
whats a "G" spot ?
Really??
Ask your girlfriend.
Old Apr 10, 2016 | 02:19 PM
Smoken1's Avatar
Smoken1
Originally Posted by LoneStarFRC
Really??
Old Apr 10, 2016 | 08:29 PM
Ron Reuben's Avatar
Ron Reuben
Cruising
Golly, here in my town, the G spot is the local diner "Georges". I guess it must mean something else where you come from !
Old Apr 11, 2016 | 04:24 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Let's keep it clean, guys...
To Pcv Valve Where Is It How Do You Replace It?
