security won't let me start car
Old Aug 18, 2006 | 01:38 PM
harley76shovel's Avatar
harley76shovel
Default security won't let me start car
I hit the wrong button on my fob, the security went off, I shut it off, but, now when I try to start the car the security light on the instrument panel stays on and will not let the car start, all the other electrical components work ie: windows, lights, radio, etc.
Old Aug 18, 2006 | 01:58 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
this has never happened to me and i am no expert at all on this system, but you might try disconnecting the battery for a little while (15 min.) and see if something resets while you wait for someone with more experiance with this stuff to post up. worth a shot anyway.
Old Aug 18, 2006 | 02:04 PM
harley76shovel
thanks, I am actually charging the battery now to see if it needs some extra juice.
Old Aug 18, 2006 | 05:25 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
let us know what the outcome is.
Old Aug 18, 2006 | 06:12 PM
JC in XTC5's Avatar
JC in XTC5
Are there any DIC codes?
Either the key pellet is no longer being seen by the BCM or your theft deterent relay is somehow shot.
You can theft deterent bypass the relay by pulling it and jumping the leads - I'll check my service manual later tonight for more details.
Old Aug 18, 2006 | 06:53 PM
harley76shovel
anything that helps, my manuals are not very clear, thanks
Old Aug 18, 2006 | 07:07 PM
200MPH's Avatar
200MPH
If you have tuning software, you can tune it out by tuning off VATS.
Old Aug 18, 2006 | 07:28 PM
harley76shovel
huh? please explain
Old Aug 18, 2006 | 07:42 PM
harley76shovel
I found a DIC code, it is C1255 which is a ECU Malfunction,
Old Aug 18, 2006 | 11:03 PM
SultansDiamond's Avatar
SultansDiamond
I shouldn't be responding because there are folks out there who really know what the problem is and how to fix it.
All I can tell you is on some of my other cars to disarm the factory alarm you would take your key and either open the passenger or drivers side with it and that was a reset.
One of us has to check the manual. Since your the one in lockdown right now... you got nothing better to do. So let us know what you find out...
I'm betting it's gonna be your ignition key held somewhere for 5 seconds.
Old Aug 18, 2006 | 11:50 PM
JC in XTC5's Avatar
JC in XTC5
C1255 is an EBCM (Electronic Brake Control Module) fault. This module controls ABS, Traction Control and Active Handling. It's probably a history code and definitely not related to your problem since it would only disable the ABS system and not prevent you from starting the car.
Once clarification. Is the Security Light OFF when you unlock the doors and get in, and then only goes ON after you put the key in the ignition? And is it Steady or Flashing. To be sure what it does, get in the car and close the door, put the key in the ignition and turn to ON. From your description the Security Light is ON. With the doors still closed, turn the ignition OFF and pull the key out . The light should go off. If it doesn't then the problem is likely with your ignition switch.
The manual is not clear, but if the light is ON it seems like the BCM is not seeing the Pass Key code or that the key is in the ignition (there's a switch to detect that).
This isn't much help, but you need to perform some detailed diagnostics with a Tech tool to isolate where the problem is.
Old Aug 18, 2006 | 11:53 PM
harley76shovel
thanks for the reply, yes, when in the car with the doors closed and key in the on position the security light stays on, no flashing, when I unlock the doors and get in the light is flashing then but, as I said when key is in on position the light stays on, I will get it to the dealer and have them repair it, thanks again for your time.
Old Aug 18, 2006 | 11:59 PM
jdmvette's Avatar
jdmvette
Night Owl for life
is your car a manual transmission? the switch at the bottom of the clutch pedal could be out. try to use a cotter pin to bridge the circuit and see if it starts.
just a suggestion.
Old Aug 19, 2006 | 12:05 AM
harley76shovel
na', automatic
Old Aug 19, 2006 | 07:22 AM
200MPH's Avatar
200MPH
huh? please explain
VATS--Vehicle anti theft system. I use HP tuners and i just turned it off. I was running into security issues with my car(not starting).
Old Aug 19, 2006 | 08:10 AM
C5XTASY's Avatar
C5XTASY
This happened to me after I ate some junk and inadvertently got some frosting on the key (VATS pellet). Clean the key, then douse it with alcohol, insert it in and out of the ignition switch several times and then reclean the key. Hopefully that'll do it for you.
Ed
Old Aug 19, 2006 | 09:46 AM
harley76shovel
how do I turn the vats off?
To security won't let me start car
Old Aug 19, 2006 | 11:43 AM
hotwheels57's Avatar
hotwheels57
...when it's determined what the issue was, will you please let us know?
I'm not sure on VATS, but I think it has to be deleted via a computer flash. I think there have been some who've bypassed the VATS with a switching device.
BTW, my first beloved Harley was a '77 FXS which I owned for 11 years. Gotta love those old Shovel motors...
Old Aug 19, 2006 | 03:51 PM
200MPH's Avatar
200MPH
HPTuners---Open up your editor and go to system--general--security--and you will see VATS, just change that to none.
Old Aug 26, 2006 | 01:49 PM
harley76shovel
Default this has been a nightmare
I need to change the entire ignition key switch, does anyone know is this a do it yourself or a dealership problem?
