C1225 code
Old Aug 19, 2006 | 01:55 PM
9T3JIM's Avatar
9T3JIM
Default C1225 code
I keep getting a c1225 code on my car and my factory manuel says that is LF wheel speed variation. Doing some research on this forum and others I find some code tables that say c1225 is the RF. Can someone clarify? Codes are being set randomly and all connections look good. I just switched sides on the cables and no code yet, but still curious about what side a c1125 pertains to.
Old Aug 19, 2006 | 02:01 PM
cliff_ford's Avatar
cliff_ford
C1225 is the left and C1226 is the right. If you look at the order the codes are in, left/right, you will see that those guides that tell you C1226 is the left, have them out of sequence. If your harness swap doesn't move the problem check the female connector on the body .
