99 C5 Steering column just locked up
Old Aug 19, 2006 | 11:21 PM
Bil's Avatar
Bil
Cruising
Default 99 C5 Steering column just locked up
is there any way to get this thing to a dealer. the msg cntr said pull key and wait 10 secs. i have tried that several times without success. right now I have disconnected the battery while on-line.
any suggestions would be greatly appreicated, thank you.
Old Aug 19, 2006 | 11:25 PM
C7GrandSport's Avatar
C7GrandSport
Happened to my 99 when I was at Corvettes @ Carlisle. A number of Corvette engineers couldn't get the darn thing going. So unfortunately a flatbed is probably in your future.
Old Aug 19, 2006 | 11:32 PM
C2Jeff's Avatar
C2Jeff
Wrong forum, methinks.
Old Aug 19, 2006 | 11:39 PM
webdzynes's Avatar
webdzynes
First of all, your in the C6 forum. You need to go to the C5 forum.
That issue is a common one and it happened to me several times. EVERY time however I was able to get it to unlock by doing this:
(Connect the battery back on) Wiggle the steering wheel HARD about 6 or 7 times and on the last pull to the right, HOLD IT THERRE with a strong pull (to the right). DONT let the pressure off. The turn the key to activate the power. It (hopefully) will unlock. This worked for me about 20 times until I bought the bypass. Also worked for several of my friends' vettes... Give it a shot and good luck!
Old Aug 19, 2006 | 11:40 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
lots of info in C5 tech...and please read the sticky over there for everything you ever wanted to know about CL and the CLB
Old Aug 20, 2006 | 12:14 AM
Bil's Avatar
Bil
Cruising
thanks very much
Old Aug 20, 2006 | 12:15 AM
Bil's Avatar
Bil
Cruising
thanks I will try that ... just learning here is the bypass an aftermarket part or GM .. where did u get yours
Old Aug 20, 2006 | 12:17 AM
Bil's Avatar
Bil
Cruising
thanks i did see that after i recovered from the initial panic .. goin back now while I charge the battery.
Old Aug 20, 2006 | 10:41 AM
Taxin's Avatar
Taxin
St. Jude Donor '06
worked for me
To 99 C5 Steering column just locked up
