2nd gear pops out on downshift occasionally
Old Aug 20, 2006 | 12:26 PM
5.0_CJ's Avatar
5.0_CJ
Default 2nd gear pops out on downshift occasionally
Is this a common problem? My old 6 speed did this, and I replaced it with a newer unit, and a few months later, it started doing it again, seems to only do it when its cold and I downshift, never anytime else.
Old Aug 21, 2006 | 07:14 PM
5.0_CJ's Avatar
5.0_CJ
ttt
Old Aug 21, 2006 | 07:27 PM
Jackal's Avatar
Jackal
You need to adjust the shifter box. There are two torqux screws that hold the shift box in place. loosen the torqux bolts, move the box back and forth until the shifter is striaght up. This is most likely the issue.
Old Aug 21, 2006 | 09:06 PM
todd@rpmtransmissions's Avatar
0todd@rpmtransmissions
Former Vendor
There is a procedure that I can email you tomorrow on how to adjust the shifter. Email me at todd@rpmtransmissions.com and I'll email you a pdf of the procedure.
Old Aug 23, 2006 | 07:24 PM
5.0_CJ's Avatar
5.0_CJ
Really? hmm.. so don't lock the shifter with the pin and loosen/tighten the hex bolts when the stick is completely vertical?
To 2nd gear pops out on downshift occasionally
