how to replace output shafts.
Old Aug 20, 2006 | 05:56 PM
killaz's Avatar
killaz
Default how to replace output shafts.
well looks like i broke an ourbut shaft. i jackeed up the back and only 1 tire spins at a time. Any write ups on how to fix em.
thx
Old Aug 20, 2006 | 06:03 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
A good start would be reading the following link.
http://www.cajundude.com/differential.htm
Old Aug 20, 2006 | 07:39 PM
killaz's Avatar
killaz
ttt
Old Aug 21, 2006 | 07:46 PM
mystifiedworm's Avatar
0mystifiedworm
Former Vendor
You will need to reomve the diff cradle, then the diff. Once the diff is on the ground then you will need find which side is broken.
Chad
To how to replace output shafts.
