Fuel consumption?
Old Aug 21, 2006 | 10:01 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Default Fuel consumption?
On our run up to Bear mountain this past weekend, I and a friend gassed up and left from the same town, did the same run, took the exact same route home. My car is an 02Z06 headers/ hi flow cats/ dynoe tune from ECS. His car is an 04Z06 stock maniflod/cats/vararam/ and a tune done by him with a preadator. I used a 1/4 tank of gas on the way up, he used 3/4 tank on the way up. I told him its his tune, running too rich, which he agreed, but he's now wondering if the vararam had something to do with it, because the filters weren't seated all the way. I'm far from an expert, so his question is, would the computer alter the car to run richer if the air flow isn't restricted by the filters? I don't think so, but i've been wrong before.
Old Aug 21, 2006 | 10:27 AM
MYCoupe's Avatar
MYCoupe
Well the computer wouldn't alter the A/F ratio to run richer. However, if there is less restriction to the air going (hence a greater amount of air gets into the engine) then the computer would add a little more fuel. I doubt this is the case as 1/2 of gas is a HUGE difference. It sounds like it's his tune and probably some discrepancy between your gas gages.
Old Aug 21, 2006 | 10:49 AM
GeorgeZNJ's Avatar
GeorgeZNJ
Thanks for the reply. BTW- I drive way more aggressivly than he does, so we've ruled that out.
Old Aug 21, 2006 | 11:03 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
If air gets by the mass air it would run leaner. With that much a difference in gas I would say he could have a leak. If he was running that fat he would be pushing out a lot of black smoke. Are his exhaust tips filthy with carbon?
Old Aug 21, 2006 | 08:12 PM
jjcslynn's Avatar
jjcslynn
I have the vararam and I just got 29 MPG on the highway from Delaware to Kentucky and back.
Probably the gauges...
Old Aug 21, 2006 | 08:31 PM
Dirty Howie's Avatar
Dirty Howie
Did he take it out of 2nd gear.........
DH
Old Aug 21, 2006 | 08:59 PM
pdd000's Avatar
pdd000
how would air get by the MAF??
Old Aug 21, 2006 | 10:07 PM
Vettez16's Avatar
Vettez16
DH
NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old Aug 21, 2006 | 11:32 PM
muncie21's Avatar
muncie21
Loose airbridge connections.
Old Aug 22, 2006 | 08:05 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
my first thought would be that either the gas gauge was wrong showing that he used 3/4 tank and/or his gas gauge is wrong and when he filled up the first time they really didn't fill it up.
I would add Techron to the gas tank first and see what happens.
Old Aug 22, 2006 | 08:48 AM
stonecoldsaysto's Avatar
stonecoldsaysto
Default Miliage
1st--- No matter how accurate You think the MPG are using Corvettes
dash readings ---- (its not accurate) The only way for the average person is to :
1-FILL the tank - & make note of ODOMETER,
2- Drive Your miles/trip & Then Fill the tank again -- noting how many miles You have driven !!!!!
3-Then Divide that # of miles by the gallons You put in on the second fill-up !!!!!!!
easy as 1-2-3 !!!!!!!!!!!!!!!!
Old Aug 22, 2006 | 09:05 AM
Geneus's Avatar
Geneus
It was the way we did it before all this on-board computer gimmickty, and it is truly the only accurate determinat of fuel economy.
Old Aug 22, 2006 | 09:21 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
C5's are notorious for gas gauge problems, so I wouldn't put much faith in them. As has been suggested, fill up and then divide the miles driven.
Old Aug 22, 2006 | 11:40 AM
Tx Ray-C5's Avatar
Tx Ray-C5
DH
Old Aug 22, 2006 | 01:25 PM
Billdog350's Avatar
Billdog350
I have a vararam, LT's, and a custom tune done myself (not a canned tune) and my car recently got 28mpg (DIC) driving up I-91 to VT (some steep hills) at 75mph. The car then was driven by my father for another 500mi for an average (DIC reading) of 34mpg!
Predators are next to useless for any sort of tuning, sounds like your buddy is running pig rich...as well as a possibility of someone's fuel gauge or DIC being off. Have him get a REAL tune and he'll be good to go.
Old Aug 22, 2006 | 06:15 PM
Vette_Fan's Avatar
Vette_Fan
Mine used to get a decent milage before I stored it for 6 months, while I was out of the country. Since I came back and drive it, it seems to be using toooo much gas. Not sure if that a gas gauge problem or just using too much gas due to other reasons. Even the DIC and analog shows gas drops so fast now.. I put in half a tank and it disppears sooner than how it was before... Not sure why..
Old Aug 22, 2006 | 06:50 PM
GeorgeZNJ's Avatar
GeorgeZNJ
Heavier foot? J/K
Old Aug 22, 2006 | 09:56 PM
jjcslynn's Avatar
jjcslynn
This was done with the 1-2-3 method, and the DIC was within 0.2 of the 1-2-3 method. Was driving 65-70 on cruise.
To Fuel consumption?
