full exhaust on..now WTF?!
Old Aug 22, 2006 | 08:27 AM
BloodRayne's Avatar
BloodRayne
Default full exhaust on..now WTF?!
I got the lg pro long tube headers with off road pipes leading to a corsa indy car cat back...Now my car sounds like ****.. I LOVE loud exhausts...Now my car actually pops and backfires maybe? I know about the motorboat sound when ya let off the gas but it pops with a loud bang when dethrottling....Also the car sounds real good under part throttle, but hen i press the go pedal, it sounds like open headers, not crisp at all..Is this normal? I changed to colder plugs b/c Im ordering a blower soon, did this cause the problem?
Old Aug 22, 2006 | 08:37 AM
WKMCD's Avatar
WKMCD
I had the Indy's on my car with LT's but with Hi-flow cats. I didn't get a lot of popping and the car screamed at you WOT. It actually sounded like an Indy car and like is was revving about 8k. It was a little too loud and I was short shifting all the time to keep it quiet. Tried the Zo6 Ti's for a while but I missed my loud pedal. Now I'm running GHL's w/ 6in cans and it's perfect.
Old Aug 22, 2006 | 09:25 AM
2000BSME's Avatar
2000BSME
same here, except I haven't switch from the Indy's yet. They sound perfect in the HPDE's on the track, but they are too loud with open cats on the street.
Old Aug 22, 2006 | 10:38 AM
mfrejek's Avatar
mfrejek
Sounds like classic exhaust leak. Start checking your connections. It's probably not really a backfire(caused by timing problem) it's air gettng sucked into a leak and igniting in the pipe. Very common. I used to used a lit cigarette and hold it by the exhaust connection points while someone held the accelerator at an elevated rpm. The smoke will be drawn into a leak.
Old Aug 22, 2006 | 10:48 AM
Uncle John's Avatar
Uncle John
That right there is a good tip.
Old Aug 23, 2006 | 01:57 AM
FASST LN's Avatar
FASST LN
Another good tip is to run cats. Otherwise it sounds like a hack-job Mustang who gutted his converters.
Old Aug 23, 2006 | 02:23 AM
oahuyahoo's Avatar
oahuyahoo
Old Aug 23, 2006 | 04:05 AM
MawneeC5's Avatar
MawneeC5
I got that sound once when I swapped cats......turned out I forgot to put the rear o2 sensors back in
Doublecheck for a leak
Old Aug 23, 2006 | 12:04 PM
BarneyZ's Avatar
BarneyZ
FWW I've read some posts, and had one very experienced installer tell me that the slip-fit connections used by LG make that system prone to exhaust leaks.
Old Aug 23, 2006 | 12:19 PM
briann510's Avatar
briann510
slip fit? do it right and weld them
Old Aug 23, 2006 | 12:29 PM
Huckzilla's Avatar
Huckzilla
Nice system
Originally Posted by oahuyahoo
Old Aug 23, 2006 | 01:13 PM
blown in n.c.'s Avatar
blown in n.c.
Do you have an x pipe or the stock h pipe? That deceleration poppin (common in f body y pipes) happens without the x pipe with headers/exhaust/cats(less).
Old Aug 23, 2006 | 01:50 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
WTF.... no... then you could never get the headers out to work on the car.
This was my biggest reason staying w/ the Kooks they use a flange type design and it doesn't leak.
Old Aug 23, 2006 | 07:01 PM
zeevette's Avatar
zeevette
My LGs don't leak at all, and the popping with an O/R X pipe is normal. However, if it's loud like a backfire, you've got a leak, or reversed O2s. The latter should make the car run rough, as well. The bandclamps that come with the headers are very easy to work with, and leak-free for over 3 years. I did change out from Borla Stingers, to a Magnaflow catback, because of excessive noise.
Old Aug 24, 2006 | 12:40 AM
Darkness's Avatar
Darkness
I got the same combo, LG's with no cats and Corsa Indy's. Except I have a BIG cam. Check sound clip in sig.
Old Aug 24, 2006 | 01:03 AM
LF97C5Vette's Avatar
LF97C5Vette
When I added B&B Bullets, there was a lot of pop and gurgle on Decel (factory H pipe) and when i added the Dynatech SupermaXX Headers (pictured above) i was afraid i'd get TONS more - but the x-pipe does a really good job of equalizing the pressure and really reduces the pop... now it only happens a little, and usually when it's cold.
I will add however, a good tune can clear up some of your problem. I read that certain tables can have a large effect on your car during decel.
GL
Dan
Old Aug 24, 2006 | 10:09 AM
chuckster's Avatar
chuckster
I hve TPIS Headers with a Slip Fit, Gutted Cats and an X pipe with Corsa Indys..
Yes it's loud and as someone said before.. The Xpipe makes it sound like a indy car reving to 8000 rpms..
I do get burble on decel.. Also if I did into the pedal hard and then lift.... I bbbbbdddddddddddddddddddddd BANG!!! Scares the **** out of the drivers behind me..
I am sure it's a leak at the slip fit.. Caus I can see soot there.. I could care less..
Old Aug 24, 2006 | 11:39 AM
BloodRayne's Avatar
BloodRayne
Thats exactly what my car does!! I must have a leak somewhere, Its more of an annoyance making everyone around me thinking my car is a POS. BANG!
Old Aug 26, 2006 | 08:18 PM
SUNNYD 95's Avatar
SUNNYD 95
Default Exhaust leak
A good way to find where you have a leak in your exhaust is, get the car up on a rack at a repair shop, start the engine and get an old blanket or a big cover, bunch it up and hold it over the ends of the exhaust pipes, it will hiss very loud wherever there is a leak in the system.
To full exhaust on..now WTF?!
