CLB question
Old Aug 24, 2006 | 07:05 PM
BJ-99's Avatar
BJ-99
Default CLB question
I bought a used C5. It's 108 drgees outside & don't want to take the dash apart. How can I tell if the CLB is installed without pulling the dash. 6 spd car. Does the column lock when the ignition is off? Mine is free to turn with the ignition off.
Old Aug 24, 2006 | 09:51 PM
zozmanZ06's Avatar
zozmanZ06
Default CLB Answer
If your column does not lock with the key off, you either have the steering locking plate removed (4006C) and/or the CLB. Run your VIN through GM VIS to determine if the 4006C recall was done.
Randy
Old Aug 24, 2006 | 10:02 PM
TEXHAWK0's Avatar
TEXHAWK0
If you cannot hear the actuator cycle when you turn the key off, then you have the aftermarket CLB installed. If you still hear the actuator cycle, but the column does not lock, then the lockplate has been removed and you probably have the Harness K kit installed.
Old Aug 25, 2006 | 01:41 AM
dataporter's Avatar
dataporter
Take the knee panel off and look. That would be the only way to tell for sure. That should take 5 minutes, maybe 10 total. Mine looks like this http://thunderracing.com/catalog/?ac...d=220&pcid=156
To CLB question
