Second recall for column lock????????
Old Aug 25, 2006 | 11:23 AM
Dually Driver's Avatar
Dually Driver
Default Second recall for column lock????????
Had the first recall done about a year ago, now I have the same problem. Dealer says there is a second recall, anyone heard about this???
Mike
Old Aug 25, 2006 | 11:32 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
See sticky above. I have an 02 & have had the earlier reflash recall (04006?) done. A while back I received a letter from GM announcing the second recall but saying that because my car had the earlier recall, they would not do the second recall unless I actually experienced a column lock problem. And that they would fix for free (new recall) only until XX/08 if it failed before then. I have CLB so no longer an issue for me. I suppose you could tell them you had a problem that forced you to shake the steering wheel back&forth to free up.
DBD
Old Aug 25, 2006 | 01:41 PM
ZeeOSix's Avatar
ZeeOSix
Get a CLB (Column Lock Bypass) to cure it once and for all. Apparently, it seems that there have been some problems on the 2nd (most recent) recall too ... something about bad K wire harnesses. Look around here on the board and you'll find so many threads on the column lock recall that it will make your head explode !!
Old Aug 25, 2006 | 06:46 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
C-L-B
Old Aug 25, 2006 | 10:19 PM
Dually Driver
DBD
Sorry about missing the 'sticky' I was so POd about being stranded again I didn't spend a lot of time looking around. I should have known you guys would have the answer if I would just look for it. Thanx for you guys that responded. You not only have a great taste in cars, but also have character, an atribute that is on the decline these days.
Thanks again, Mike
To Second recall for column lock????????
