Replace steering rack at 125,000 miles?
Old Aug 29, 2006 | 10:33 PM
Corvettes White's Avatar
Corvettes White
Default Replace steering rack at 125,000 miles?
We have 125,000 miles on the car. Currently the front rad pack is out along with the ABS mounting. Replacing out the steering rack now as opposed to 2 years from now sounds like a good idea.
Any thoughts guys?
Thanks in advance. George
Old Aug 29, 2006 | 10:57 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Why?
Old Aug 29, 2006 | 11:12 PM
Corvettes White
Only because it is very easy to get to right now and will not be when I put the car back together. I do not know what the life span is on the part.
George
Old Aug 30, 2006 | 10:05 PM
Corvettes White
Old Aug 31, 2006 | 12:57 AM
Dirty Howie's Avatar
Dirty Howie
Mine started leaking like a sive ..... its being replaced at the dealer right now ...... car has almost 74K on it.
DH
Old Aug 31, 2006 | 01:35 AM
Corvettes White
My problem is I also own a ’69 where every 30,000 miles you rip something out and replace it. Now I know that times have changed, but if I were this far under our C3 I would just be trashing the power cylinder and starting over. On the other hand, the steering gear box runs a 100,000 easily. Therefore, I lack a point of reference here.
Anyone with 200,000 miles on his C5?
Old Aug 31, 2006 | 01:41 AM
TTK98's Avatar
TTK98
Ours started leaking badly out the passenger side tie rod seal.Picked up a used rack off the Bay and just installed it last weekend. All the work is from the bottom of the car and the drivers side wheel well. Did not remove any part of the cooling system.
I would suggest you just leave it and deal with it, if ever in the future.
To Replace steering rack at 125,000 miles?
