headlight cover alignment question
Old Aug 30, 2006 | 11:08 AM
mcmtac14's Avatar
mcmtac14
Default headlight cover alignment question
Hello all,
I am not please with the gaps around the hradlight cover on my 2002 coupe and was wondering if there is a way to align it. The gap on the hodd (inside) is far larger than the outside gap. The car was not in an accident....
I have removed the cover at the (4) torx screws and there is a bit of ajustabilty up and down to make the cover fit flush... it does... just poor gaps around the seems!
Thanks in advance,
mcmtac14
Old Aug 30, 2006 | 12:15 PM
nuke61's Avatar
nuke61
The plastic structure underneath the metal headlight cover is adjustable front/back and left/right. You loosen the Torx screws and then just move it around. On this plastic piece are the height adjustment screws that you're talking about.
Old Aug 30, 2006 | 01:16 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
nuke 61 is right. And it is a real time consuming ordeal to get them right. Once you do, mark each location with a dab of paint for when you have to remove the covers.
To headlight cover alignment question
