Brief Explanation needed on Fuel Filter...
Old Sep 10, 2001 | 02:07 PM
FRPTech's Avatar
FRPTech
Default Brief Explanation needed on Fuel Filter...
OK all,
Can anyone explain the fuel filter/regulator setup on on C5s?
I see we have two lines coming in and one going out on the filter itself. I'm assuming this has to do with the built-in regulator/return issue but would like some clarification as I'm adding an inline booster pump and want to make sure I tap the correct line ahead of the filter.
Thx.
FRPTech
Old Sep 10, 2001 | 02:28 PM
C5Noir's Avatar
C5Noir
Default Re: Brief Explanation needed on Fuel Filter... (FRPTech)
Just an aside here, if you're removing the fuel lines that go to the filter, can you take a pic or tell me where you can get the tool to remove the fuel lines from the filter? Thanks, FRPTech
[Modified by C5Noir, 12:29 PM 9/10/2001]
Old Sep 10, 2001 | 02:54 PM
FRPTech's Avatar
FRPTech
Default Re: Brief Explanation needed on Fuel Filter... (C5Noir)
C5Noir,
I've been user there a few times. Incoming side of the fuel filter uses standard quick connect fittings. They have blueish colored clips on the end of the fitting - just squeeze'em with a small pliers and pop the lines off just be careful not to break them. Outgoing side of the filter uses the Quick Connect fitting off a braided line - similar to what you see on your fuel rail - you need a "fuel disconnect tool" for this. Its basically a small plastic ring with a sleeve that slides into and pops the connection. They are available at Pep Boys and most other national auto part chains for like $8 for a set of various sizes.
FRPTech
Old Sep 10, 2001 | 06:31 PM
C5Noir's Avatar
C5Noir
FRPTech, thanks a million, I appreciate it!
To Brief Explanation needed on Fuel Filter...
