Tire Pressure Sensor Update
Old Sep 10, 2001 | 04:45 PM
slogan_98's Avatar
slogan_98
Default Tire Pressure Sensor Update
I have assumed that the tire pressure sensors on my '98 had batteries in them but was told on more that once that there was no battery and the power was generated by some type of counterbalance similar to a self winding watch. That made some sense since the pressure was not displayed until 10-15 mph.
The mystery has now been solved because yesterday I dissected a bad sensor and the do have batteries. All of the components are sealed in epoxy so the units are not repairable nor can the batteries be replaced. Just thought I would pass the info along.
Old Sep 10, 2001 | 04:59 PM
Reeves's Avatar
Reeves
From: The inmates are running the asylum... San Jose, CA
Default Re: Tire Pressure Sensor Update (slogan_98)
If you have pictures of the disected sensor, I'd love to see them (and assume others would as well :D).
Old Sep 10, 2001 | 05:02 PM
Green Hornet's Avatar
Green Hornet
From: Well Mr. Peabody, where are we going today? Virginia
My users' manual says that the batteries will last approximately 7(?) years, if I remember correctly.
Old Sep 10, 2001 | 06:28 PM
slogan_98's Avatar
slogan_98
Default Re: Tire Pressure Sensor Update (Reeves)
Sorry but at the time I wasn't thinking about pictures. Since everything is imbedded in epoxy you have to break it apart as you chip pieces out so there wasn't much left of it anyway. I can tell you that the battery is on one end and is about the size of a quarter.
Steve
Old Sep 10, 2001 | 06:30 PM
slogan_98's Avatar
slogan_98
Default Re: Tire Pressure Sensor Update (Green Hornet)
Yeah I am sure that is why they only register at speed so that the battery is not being drained all the time.
Steve
Old Sep 10, 2001 | 09:27 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
4volt lithium battery that resembles the one in the transmitter...sensor battery goes into sleep mode when stationary... :sleep:
Old Sep 11, 2001 | 08:35 AM
Green Hornet
Default Re: Tire Pressure Sensor Update (C-5 TECH)
My DIC displays pressure in all 4 wheels when parked in my garage. The pressure seems accurate (31 lbs, cold).
Old Sep 11, 2001 | 08:57 AM
CarolinaC5's Avatar
CarolinaC5
That's the last pressure it took when you were driving the car
Old Sep 11, 2001 | 09:25 AM
steve1173's Avatar
steve1173
Default Re: Tire Pressure Sensor Update (CarolinaC5)
Had 30 pounds in cold in all 4 tires, raised to 32 but after driving a few minutes still registered 30 on the DIC.
Old Sep 11, 2001 | 09:48 AM
slogan_98's Avatar
slogan_98
Default Re: Tire Pressure Sensor Update (steve1173)
You gotta go over 15 mph before they will register and cycle through the guages button again.
Old Sep 11, 2001 | 10:17 AM
steve1173's Avatar
steve1173
Did that, was at 45mph when I went thru the gauges button, still read 30 pounds even though I added 2 pounds from 30 right before the drive.
Old Sep 11, 2001 | 11:18 AM
AllVette's Avatar
AllVette
An interesting note about the sensors:
I occasionally drive my car to the track with my autocross tires on it, these wheels do not have sensors in them. The tire pressure that is displayed in the DIC actually changes to reflect ambient conditions. Apparently the sensors transmit 'absolute' pressure (relative to a vacumn rather than atmospheric). The computer then adjusts this based on the ambient conditions. Its pretty weird to see the tire pressures go up as the temperature rises when there are no sensors present.
David
Old Sep 15, 2001 | 07:06 PM
Green Hornet
When I park it at night, the pressure is 35. When I turn it on the next morning (before leaving the garage) the pressure is 31. It doesn't have to be driven to register the pressure.
Old Sep 16, 2001 | 12:03 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
According to my Service Manual, the 2001 sensors (don't know about other years) go into a sleep mode if the car has not moved for a while, and only transmitt a pressure reading once per hour. But that would be enough to give you the correct pressure as the tires cool overnight. I've also noticed that if I put air in the tires and then drive right away, it can take a mile or two for the additional pressure to show up on the DIC, but I don't know why. Also, last winter I put on the Winter EMTs and forgot to retrain the sensors- I drove about 70 miles before the DIC finally told me to service the system. Strange.
To Tire Pressure Sensor Update
