Fast blinking
Old Aug 31, 2006 | 10:10 AM
jdonnelly's Avatar
jdonnelly
Default Fast blinking
Just got back from a track day. Picked up the car from the shop and noticed my turn signals are blinking really fast. All the bulbs are working. The wierd thing is that with the emergency flasher on everything blinks at a normal rate.
I do have a european light harness for the rear tail lamps. If I go to the stealer they will probably blaim the "aftermarket" part and charge me for the diagnosis.
Is there a check that I can do? I hhave heard that there are 2 flashers. One on the fuse block by the battery and the other???
Jeff Donnelly
Old Aug 31, 2006 | 11:35 AM
blown in n.c.'s Avatar
blown in n.c.
sounds like you have a light out or your car thinks you do because of the harness.
Old Aug 31, 2006 | 11:40 AM
jdonnelly's Avatar
jdonnelly
The harness has been in the car for 2 years and there is no bulb out. All the turn signals blink.
To Fast blinking
