Point & Shoot
Old Sep 1, 2006 | 11:04 AM
James L. Baskett's Avatar
James L. Baskett
Default Point & Shoot
I need to buy a Haynes and/or Chilton!
In the mean time, can someone tell how to alien these fog lights?
Old Sep 1, 2006 | 12:37 PM
BlackZ06's Avatar
BlackZ06
Based on the Service Manual for a 2001 ....
* Fuel level should be 1/2 full or less
* Jounce car to settle the suspension
* Cover/block headlamps to make aiming easier
* Place a screen 25 feet in front of the vehicle with a line drawn horizontally at the height of the center of the foglamps (You'll have to measure this ... the manual doesn't list the height)
* Turn on the Fog lamps (duh!!!)
* Insert a TORX driver through the front fascia deflector access hole to reach the fog lamp vertical (there is no horizontal) adjustment screw.
* Adjust lamp so that the top of the high intensity zone is 4 inches below the line on the screen.
* Turn OFF fog lamps (double duh!)
Old Sep 1, 2006 | 12:56 PM
94legaleagle's Avatar
94legaleagle
I don't believe their is a Haynes or Chilton manual for the C5 Corvette - you need to get the 3 volume Helms manuals if you want to do your own service work
Old Sep 6, 2006 | 12:39 PM
James L. Baskett
You wouldn't know what size TORX you need?
Old Sep 6, 2006 | 01:51 PM
BlackZ06's Avatar
BlackZ06
Sorry, no, manual doesn't usually list bolt/screw sizes. I was surprised it even pointed out that it is a TORX driver needed.
Should be a "standard" TORX size though, or the tool would be listed in the "Special Tools and Equipment" section, and it's not.
Old Sep 6, 2006 | 02:41 PM
seering's Avatar
seering
I think its a T15
At least thats what i think i used to adjust them late last week.
Old Sep 6, 2006 | 04:20 PM
Silver98's Avatar
Silver98
and NO, no one makes a "manual" for the C5. The only recourse is to buy the GM service manuals. The 3 volume set runs near $120. Ken Fitchner has had the best price going for the last 3 years.
To Point & Shoot
