Fishtailing
Old Sep 1, 2006 | 09:55 PM
BLCK PRL's Avatar
BLCK PRL
Default Fishtailing
I put Blackwing CAI and Corsa Indy exhausts on my wife's '04 vert. I got it dyno tuned and gained 34 rwhp and 30lb torque. Now, when she punches it at low speeds the rear end fishtails a lot, when going straight ahead. Any suggestions as to the cause or to correct the fishtailing? The max power on the dyno sheet was 314hp. That doesn't seem like that much HP to cause the car to that.
Old Sep 1, 2006 | 10:01 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
She does have the traction control / active handeling on right. If so check for any codes on the DIC.
Old Sep 1, 2006 | 10:23 PM
4DRUSH's Avatar
4DRUSH
this may sound simple but don't hit the gas so hard when pulling out, like you would have to do with a mini van etc. That much HP should not be hard to handle
Old Sep 1, 2006 | 10:25 PM
ChipN's Avatar
ChipN
It almost sounds like torque management was minimized or disabled during the dyno tune.
Old Sep 1, 2006 | 10:30 PM
tsts's Avatar
tsts
Did similar changes like your and have same problem, Is the car automatic (A4). If so, if found if it downshifts two (2) gears to first , all hell breaks loose. If I know I might have to punch it, like when entering fast moving traffic, I try to shift manually so the engine doesn't kick down as hard. this is with TC on.
Old Sep 1, 2006 | 11:00 PM
David426's Avatar
David426
So the dyno was 280 rwhp before the mods. Sounds a little low. The traction control has brain farts and will often not kick in until the car is sideways. This has been my experience
Old Sep 1, 2006 | 11:17 PM
debmwb's Avatar
debmwb
Fishtailing when you punch it is not really a "problem". It usually means that the tires are spinning. This is a good thing! If you perceive it as a problem, then you have to learn how to drive it differently after the mods...i.e., don't punch it so hard so it doesn't fishtail!
Old Sep 1, 2006 | 11:28 PM
C5Stunner's Avatar
C5Stunner
Default Lmao!
Old Sep 1, 2006 | 11:44 PM
BLCK PRL's Avatar
BLCK PRL
Yes...Active Handling is ON and yes it's an A-4 automatic. Deb...I agree and I told her that she just needs to get use to the added power. She use to drag race 40 years ago and even today she drives it like she stole it.
Old Sep 1, 2006 | 11:48 PM
debmwb's Avatar
debmwb
Gotta Love it! Oh....put that thing into "comp" mode and see what happens!
Old Sep 2, 2006 | 12:00 AM
vetracn98's Avatar
vetracn98
St. Jude Donor '08
Manual shifting does help a ton with that one.
Old Sep 2, 2006 | 12:22 AM
gdphillipsvette's Avatar
gdphillipsvette
Unplug a couple of plug wires...!
Old Sep 2, 2006 | 12:35 AM
VLVETTE's Avatar
VLVETTE
What tires and how many miles on them? After about 5000 the runflats harden up and don't bite for shiznit.
Old Sep 2, 2006 | 12:41 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Roll in the throttle. Don't stab it.
Old Sep 2, 2006 | 12:44 AM
Bill Dearborn's Avatar
Bill Dearborn
How much extra power do you really have at low speeds? At 10 or 20 mph in low gear what RPMs are you running? If you floor it at those speeds and the car drops to low that is all the RPM you are going to see until the engine accelerates. Your dyno tune and mods added 34 HP at the peak. You can look at your dyno graph to see the delta power for the RPM at lower engine speeds. At lower RPMs like 2000 the difference is probably less than 10 HP. Not a reason to suddenly see some fishtailing. Sounds like different driving.
Bill
Old Sep 2, 2006 | 01:42 AM
BLCK PRL's Avatar
BLCK PRL
Bill
Hey Bill......I'm not going to be the one to tell her that she doesn't know how to drive.....Common sense is the better part of valor....LOL
Old Sep 2, 2006 | 02:13 AM
Uncle John's Avatar
Uncle John
Thats seriously funny
Old Sep 2, 2006 | 02:19 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Sounds like the only available option is to get Z06 size wheels and stickier tires.
To Fishtailing
