Need to shield starter from header heat...
Old Sep 3, 2006 | 11:36 PM
5W0P3's Avatar
5W0P3
Default Need to shield starter from header heat...
Anyone know of the best way to do this? Everytime i drive the car about 30-40 miles, and then pull into the gas station to get something to drink or whatever, it wont start back up. This started a little after changing the headers. Anyone else had this problem and have a good solution?
Old Sep 3, 2006 | 11:43 PM
frodo84's Avatar
frodo84
Uneducated autodidact
You can buy a starter shield from Summit racing...or go to Lowes or Home depot and buy an insulating cover for a barbeque pit (for a lot less) and cut it up and install. I've done both on my C4 and C5, the barbeque pit option was a lot cheaper and not hard to install.
my opinion, of course.
Old Sep 4, 2006 | 01:03 AM
muncie21's Avatar
muncie21
I'd get under there and recheck the tightness of the elctrical connections on your starter. This is not a common problem for header cars.
Old Sep 4, 2006 | 01:12 AM
4DRUSH's Avatar
4DRUSH
Old Sep 4, 2006 | 02:03 AM
5W0P3's Avatar
5W0P3
I'll check that out asap. Thanks!
Old Sep 4, 2006 | 08:38 AM
Pumba's Avatar
Pumba
Jeff,
Thermo-Tec sells an exhaust insulation tape. I install this on my right header after I cooked the starter:
http://www.thermotec.com/products/full/11001/11001.html
Old Sep 4, 2006 | 12:45 PM
5W0P3's Avatar
5W0P3
Originally Posted by Pumba
Jeff,
I've never seen it happen. I've only HEARD about it happening. But, i've heard that stuff can catch on fire!
Old Sep 5, 2006 | 03:27 AM
Rollin Black's Avatar
Rollin Black
Hello.
Lingenfelter sells a starter heat shield that should work for you.
http://www.lingenfelter.com/Merchant...Category_Code=
Old Sep 5, 2006 | 12:45 PM
hotwheels57's Avatar
hotwheels57
I'm relatively new to C5/Z06 technology myself, so this might not work with an LS motor (I don't know why not). First, as suggested, confirm all electrical connections to be secure and uncompromised. I'm not a fan of "wraps" which usually only mask the issue rather than cure it.
In street rods and "old technology" high HP and compression ratio cars we use a Ford type solenoid to take the load off the electrical system (starter switch and starter solenoid). That will cure any hot start issue for sure. You can check with MADD ENTERPRISES electrical guru Mark Harmon regarding the remote solenoid.
Old Sep 5, 2006 | 01:45 PM
5W0P3's Avatar
5W0P3
I too am familiar with the ford system. I'm really hoping its just a loose wire.
To Need to shield starter from header heat...
