tire size?
Old Sep 4, 2006 | 01:54 PM
fastbluels6's Avatar
fastbluels6
St. Jude Donor '10
Default tire size?
kinda stupid question but if im running a 35 series tire on an 18 inch rim in the rear what series do i run in the front if im using an 18 inch rim in the front. the car is already lowered so im not worried about adjusting the suspension.
thanks...
Old Sep 4, 2006 | 04:32 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
35 or 30
Old Sep 4, 2006 | 04:54 PM
Sinister C5's Avatar
Sinister C5
Default Formula for figuring OD tire size
Hi guys,
I'm new here but I do know the formula to figure out the O.D. (outside diameter) of tires when you are changing to different size rims.
245 45 17 = 245mm divided by 25.6 = 9.57inches wide
multiply 9.57inches by .45 (aspect ratio) = 4.306 inches =
sidewall height
4.306 multiply by 2 =8.613 inches +wheel diameter 17inches
= Outside Diameter =25.613inches
245 = width metric
45 = aspect ratio = .45
17 = wheel diameter
You can use this formula the exact same way with different widths, aspect ratios, and wheel diameters to find a combination that will be the roughly the same outside diameter to keep from having clearance problems yet run bigger wheels.
example
245 40 18 =25.656 inches outside diameter and same width as stock.
Hope this helps
Sinister C5
Old Sep 4, 2006 | 06:00 PM
Darion's Avatar
Darion
Originally Posted by Sinister C5
Hi guys,
sidewall height
245 = width metric
17 = wheel diameter
example
Hope this helps
Sinister C5
Sinister C5,
Nice info and to ad to that here is a tire size calc. to make it even easier;
http://www.1010tires.com/TireSizeCal...?action=submit
and one for wheel offset;
http://www.1010tires.com/WheelOffsetCalculator.asp
as for front 30 or 35 depending on the width of the tire when compared to the rear, could go either way. Plug in the sizes you are interested in into the tire size calc and check for % of difference front to rear. Stock Z06 sizes return a 3% and stock coupe sizes return about a 3.5% diff front to rear.
Hope this helps,
Darion
Old Sep 4, 2006 | 08:49 PM
skip89's Avatar
skip89
Ttt
Old Sep 5, 2006 | 01:01 AM
striper's Avatar
striper
You didn't mention the width of your rims or the rear tire size you are running but here are my specs. I have 18" x 10" front and 11" rears. I have 295/35 rear tires which are the stock Z06 rear size. Up front I have 265/35 on the 10's which visually look good compared to the larger rears and also are the same diameter as the 17" front OEM tire size. You can also use a 275/35 in front also.
To tire size?
