Can you identify this part?
Old Sep 4, 2006 | 02:12 PM
veni vidi vert's Avatar
veni vidi vert
Default Can you identify this part?
Anyone recognize this?
It's by the ambieant air temp sensor on the right hand side of the car by the air dam.
I cant find any wiring to plug it into
Old Sep 4, 2006 | 02:39 PM
IM QUIKR's Avatar
IM QUIKR
that's what it is. You'll have to search around to find the plug on the harness. I think it's over by the horns.
Old Sep 4, 2006 | 03:04 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
What year is your Vette? Mine '98's is located on the driver's side and looks quite similar to yours and should be the air temp sensor! Look closely the wire lead could have come off and fell down by the pulley's and got chopped off!(hope not though!)
Are you getting any codes with this pup unhooked!
OR! perhaps it is the stocker and someone did the relocation recalibrated kit and left the stock one in the stock location instead of plugging it(which I did to mine! that is plug the left over hole!) and run the new one to the new location closer to the MAF!
Let us know how it goes!
Thanks,Matt
Old Sep 4, 2006 | 03:17 PM
IM QUIKR's Avatar
IM QUIKR
that sensor is the outside air temp sensor and sits at the mouth of the rad shroud lower passenger side. You are confusing it with the IAT sensor(intake air) which is up by the MAF.
If you can see a temp sensor in that place it may have been replaced and that part is the one he may have lost.
Old Sep 4, 2006 | 07:19 PM
veni vidi vert
Thanks for identifing it. There's one on the car, so this one must have been replaced and they left it...
To Can you identify this part?
