Where can I purchase red brake caliper paint, same red as ZO6?
I see lots of vendors selling red. For example, Auto Zone sells a kit from Dupli Color, but just not sure that the Dupli Color red is the same as the GM ZO6 red.
This is what I used. Great stuff. Not too red, just right if you know what I mean. Just make sure you get the caliber really clean with a paint prep to prevent fisheyes.
Alot of owners use RustO'leum Sunrise Red. Small can is about $5 at Lowes or HomeDepot. Brush on a couple of coats, and it lasts a long time. Keep it simple!
I've heard somewhere that DupliColor FORD red is the closest to the actual red color painted on by the factory - that's what I used (actually, I used Duplicolor primer, then Duplicolor FORD red, then Duplicolor clearcoat) then use a razor blade to scrape the paint off of the "CORVETTE" letters on the caliper
