Harmonic balancer removal tool
Old Sep 7, 2006 | 01:00 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Harmonic balancer removal tool
I removed an LSx harmonic balancer before using one of those gear pullers from Advance Auto Parts. It worked, but was a bit of a pain in the butt. For those of you who have pulled balancers a lot, what tool do you use, and where can I get one? I really don't want to have to go back to a puller that won't pull the balancer straight off, requires constant realignment, doesn't fit quite right, etc.
Old Sep 7, 2006 | 09:59 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Old Sep 7, 2006 | 10:19 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
From what I've heard a standard 3 arm puller with the arms on the short setting works fine. Will be doing this myself in a couple of days so too.
Old Sep 7, 2006 | 10:31 AM
Evolution's Avatar
Evolution
I use the adjustable three claw type where you can tighten the claws so they do not move. You can turn the claw arms around for a longer or shorter reach. Mine worked great.
Old Sep 7, 2006 | 11:34 AM
N0TDADYS_98's Avatar
N0TDADYS_98
i used the 3 claw... but when i last replaced it with an aftermarket UD it had a 3 bolt system for removal... which is a much better design IMHO.
Old Sep 7, 2006 | 11:41 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Yeah, we have the worst of both worlds on the factory pulleys. No keyway so it has to be press fit, no bolt holes so you can't use standard pullers and installers, and the bolt is torque to yield so you either buy a new one or use an ARP bolt. No biggie.
I just ordered a balancer installer from a guy on LS1Tech that makes a custom piece that a lot of people have had good luck with. I also saw over there, they recommend the Craftsman 3 arm puller. Seems a lot of people had good luck with that too.
I think I'm set now
Old Sep 7, 2006 | 12:38 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
I think I'm set now
You too huh?? Just bought one from him myself.
To Harmonic balancer removal tool
