NEED HELP ASAP car wount start
Edit - looks like it is running but on reduced power.
Do you know the codes that you are getting???
PCM CODES
P0601 PCM Memory
P1518 PCM to TAC Module Serial Data Circuit
TCS CODES
C1276 Delivered Torque Signal CKT Malfunction
RDCM CODES
U1064 Loss of Communications with BCM
i got all these codes after this happen ..i i didnt have any problems or codes before this happened
here is more:
C1276 says if P1518 is present then go look at that error.
P1518 says it is the communication between the trottle actuator control and the powertrain control module.
this could be set off because of low voltage from the battery.
it could also be a blown fuse that was setoff by a short.
read this and it may help you locate the problem
http://www.gearchatter.com/viewtopic10423.php
If so, the EBCM may have been confused by that. Wouldn't account for the car not starting, but might explain the TC/AH codes.
When you try to start it, what happens ... does the starter "click" and not turn the engine over, or does it turn over the engine ?? What voltage is the DIC and/or gauge displaying for the battery?
PCM CODES
P0601 PCM Memory
My 2001 Service Manual says the P1518 is when the PCM cannot communicate with the Throttle Actuator Control. This should set a CHECK ENGINE light and also give you REDUCED ENGINE POWER.
The P0601 is more serious. The PCM failed an internal test of the microproccesor.
All codes should be followed by either a "C" or an "H" - Current or History. I'd clear the codes and try starting the car. If it won't start, check and see if rhese same codes are set. If you get the P0601 the car will need to be towed to a dealer for the PCM to be checked and possibly reprogrammed or replaced. If the P1518 reappears check wiring to the Throttle unit, but that probably is also gonna require a tow.
Good luck, hopefully these were "H" codes and the car will start.
The two I'd look into are the PCM and TAC codes. I'd ignore the BCM as none of those codes are posted by the BCM. Any DTC starting with a P comes from the PCM. BCM codes usually start with a B (for Body).
Be sure you've cleared the codes, cycle the PCM diagnostics until you get a clear run that says "NO CODES", then try starting. If you continue to get rhe P0601 I can only tell you what the 2001 Service Manual I have shows.
It says if you have a P0601 and NOT a P602 ... then next step is REPLACE PCM. Not pretty.
Obviously check connectors to PCM, but if that code keeps coming up ... well ..that's what the 2001 Manual shows.
again i would not believe your battery. Change it out and eliminate that 100%. I talked to a guy a couple of weeks back and he thanked me for suggesting the battery. He also showed good volts across the battery, but the battery was no good.
Then start looking at fuses and connections. If you cant see anything wrong then you will have to get a tuner to look at it.
When you turn the key to start the car, the BCM is in charge of SECURITY, and once it has decided that all is well (the resistor in the key matches what the BCM has stored, etc.) then the BCM sends the password to the PCM. Without the correct password, the PCM will not start the engine (I believe it will crank, it won't run).
At this point, if you've tried the following ...
1) new battery
2) checked ALL fuses
3) checked wiring for bad ground or exposed (bare) wiring
and you're still showing the P0601, then a dealer is about your only option. To reprogram, or install a new, PCM requires two things:
1) Tech 2 scan tool
2) Access to the GM Techline
The GM Techline access allows the Tech2 to get the correct software for your PCM based on your VIN. Without access to Techline, the Tech2 cannot reprogram your existing PCM, or a new one.
