car died
Old Sep 7, 2006 | 11:09 AM
N0TDADYS_98's Avatar
N0TDADYS_98
Default car died
This is the 2nd time it's happened for no reason...
sorry i haven't pulled codes yet and will do tonight... but heres what happened.
The other day i'm coming home from drill.. I'm just casually driving... didn't get on it once.. just nice smooth easy shifting, tops off, just enjoying my ride...as i approach a red light i insert the clutch and apply the brake and then i hear a ding from the dash... REDUCE ENGINE POWER... i noticed the car is trying to shut down so i gave it some gas to see if i couldn't get a guage to stand out... it was too late car died... so i try to start it.. and it wouldn't start... finally i wait a min and try again and it starts up no big deal no prompts no studder just drives off..
Then yesterday i'm coming home and the same thign happens... This time i came from a higher speed to stop... i was about to make a rolling stop and when i let the clutch out, and noticed i had next to no power... Again the message REDUCE ENGINE POWER came up... shut down and tried starting it and still the same problem.. hit the flasher, pulled the key waited a 30secs and tried it again and Vaooooooooooooom power restored as if it never happened...
1998 Coupe MN6 115k miles
Mods:
228R TSP cam,
LS6 intake
TSP long tubes
!cats
Factory H
Corsa Exhaust
PRC springs, harden pushrods
Underdrive pulley
Tuned---------*but the tempature outside was about 100* so it will need to be tuned again once tempatures come down some more..
any ideas whats causing this?
Old Sep 7, 2006 | 05:15 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
I put money on bad ground wires somewhere. If you look at the top of this forum there is a sticky by Bill Curlee i think, he explains how to check your grounds
Old Sep 7, 2006 | 06:42 PM
FRCTony's Avatar
FRCTony
TAC module.
Old Sep 7, 2006 | 09:29 PM
rkerr1234's Avatar
rkerr1234
Mine kinda did the same thing and it was the steering lock recall problem, they said it needed adjusting, just a thought, good luck
Old Sep 7, 2006 | 09:34 PM
rpm462's Avatar
rpm462
Possibly clogged injectors??
Old Sep 8, 2006 | 01:58 AM
N0TDADYS_98
Originally Posted by FRCTony
TAC module.
as in traction control?
I do recall seeing that flash too now that i think of it..... where is the TAC module and is there a way to inspect it?
Old Sep 8, 2006 | 03:48 PM
FRCTony's Avatar
FRCTony
Do a search on TAC module. This is a common problem on early cars. It is located in passenger fenderwell beside the PCM.
Old Sep 8, 2006 | 04:17 PM
N0TDADYS_98
Thanks tony.
Old Sep 8, 2006 | 04:28 PM
FRCTony's Avatar
FRCTony
Don't forget to pull the codes first. This problem should set very specific ones.
Old Sep 8, 2006 | 05:56 PM
corvette Mark's Avatar
corvette Mark
This is a total WAG but you mention that your tune may be off a bit. You say this happens when you hit the brakes which could be a vacuum problem or the possibility that when you hit the brakes to slow to a stop your idle RPM is dipping too low and causing the codes to be set.
Old Sep 9, 2006 | 08:34 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Man,
you have had your share of problems after modifying that car.
Dont let it get to you. Fix it and have fun again
To car died
