Name that Noise
Old Sep 7, 2006 | 08:37 PM
Hoosier05's Avatar
Hoosier05
Default Name that Noise
I have a '99 Coupe with a 6spd. I'm getting some squeaking noises from my belt under certain engine loads, particularly at 60mph in 6th gear. I've already replaced the main drive belt and the tensioner. Anybody have any ideas or has anyone experienced this problem as well?
Thanks in advance
Old Sep 7, 2006 | 08:49 PM
C6NRED's Avatar
C6NRED
The only thing that I can suggest is that with these serpentine belts, if any one of your pulleys is not perfectly aligned, they will squeek. Do NOT, I repeat do NOT ever use belt dressing on these belts. It will quiet the problem for a mile or two, and then it will come back worse than ever and NEVER go away, as any residue on the pulleys will make it slip enough.
Old Sep 8, 2006 | 12:47 AM
blue99frc's Avatar
blue99frc
Does it squeak with the air condition on and off? There is a separate belt for the air condition compressor.
Old Sep 8, 2006 | 07:29 AM
Hoosier05's Avatar
Hoosier05
The noise is the same with or without the AC on.
Old Sep 8, 2006 | 07:57 AM
searcher1979's Avatar
searcher1979
Had the same problem, changed the belt on the ac and the pulley. Noise gone!
Old Sep 8, 2006 | 11:57 PM
Hoosier05's Avatar
Hoosier05
Sounds like I'll have to give that a try next. Thanks for the help
To Name that Noise
