HELP! Can't stop targa top from squeaking!
Old Sep 11, 2001 | 07:49 PM
RichieRich's Avatar
RichieRich
Default HELP! Can't stop targa top from squeaking!
This is a problem that only occurs sometimes and I've been unable to tell exactly where on the top it's coming from. I've tried tightening everything, greasing it up, etc... Any ideas? It drives me crazy. Any time I go over a speed bump, rough surface, anything that causes the body to flex I hear it. :mad
PLEASE HELP!
Old Sep 11, 2001 | 08:01 PM
C5Noir's Avatar
C5Noir
Default Re: HELP! Can't stop targa top from squeaking! (RichieRich)
It's most likely the latches. Take off your top and and look at the sliver plate on the latches, usually they're loose and this causes them to make noise. If you look at the latches from the side you should see a gap between the sivler plate and the latch underneath, if there's a gap and/or some play in it, it's your culprit. If so, replace the latches.
[Modified by C5Noir, 6:02 PM 9/11/2001]
Old Sep 11, 2001 | 08:44 PM
THENAKEDi's Avatar
THENAKEDi
I had exactly the same problem on my '99. I went to the dealer several times to fix; however, nothing seemed to work. Finally, I isolated the surfaces of the latch contact points with a business card and voila, no more creaking. I know this is not the best fix, but it works and after awhile I forgot about my makeshift solution...
Good Luck.
Old Sep 11, 2001 | 11:37 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Remove the top and tighten the front left and right latch brackets.These are the brackets mounted to the windsield pillar behind the center garnish molding.You can get a 10mm wrench behind the garnish molding to tighten the 4 bolts.You will find that you can get a least 1 full turn on them...
Old Sep 16, 2001 | 12:27 AM
ScreaminDemon's Avatar
ScreaminDemon
I also have had the same problem. It turned out to be the small metal plate that covers the little roller on the top frame rail of the windshield where your top secures in. You can tap it with your finger and know it's loose.It seems to just be clamped in place and had become loose. I tried to tighten it with some pliers but eventually just glued it down. Use some really good 3M stuff...
Old Sep 16, 2001 | 12:42 AM
laramr's Avatar
laramr
Active Streak: 90 Days
Lately it seems that the solution is to not engage the latches! :D
Sorry, couldn't help myself.
Old Sep 16, 2001 | 02:12 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I hate to post anything after C5 tech... I know his answers are always right on the money.. I am always amazed at how a guy.. or guys in our case.. Our two resident techs post so much useful information.. here.considering this is not a hobby for them.. it's their job.. Thanks you guys for just being here..
OK that being said..I have used Dielectric Lube on areas that make noise..
A tube can be bought at any parts store.. I use it on my wifes sun roof gasket.. it's good stuff..
To HELP! Can't stop targa top from squeaking!
