Ok I have gotten a few more codes after my cam install the new ones are P0300 and P1153. I have LG streets also for more info. I know the That the P0300 is engine misfire probably do to the MS3 install, and the P1153 H02 insufficient switching. My question is will the Cam cause these codes? The LT's have been on the car for like 7,000 miles and I have never gotten the P1153 code before the other day when the cam was finished. Lastly will either one of these codes prevent me from getting tuned this coming week?
Will NOT effect your upcoming tune. Cam causes misfires easy fix for tuner. Switching could be lazy sensor or less exhaust heat with cam and LTs (reversion).
FWIW.
Ok from I have gathered from vatious people is the missfire will be corrected by adding timing down low cause of the cam like you said. Im just worried that the 02 might have crapped out suddenly and that will cause the car to act funny and not be able to tune. I know in the past on other cars that when the front 02's go bad if messes the car up bad and wont run right.
Buy a spare 02 and make sure that the place will take it back if its still in the box. Then bring it with you and you can install it at the tuner shop if necessary. I'd rather have a spare since the tuner is going to be dedicating a lot of time for you to get it done right, it'd be good to do it right the first time.
