Defroster Help
Old Sep 11, 2001 | 09:22 PM
steve1173's Avatar
steve1173
Default Defroster Help
Have a 2001 Coupe, with the manual climate control. When put in the defrost mode get lots of noise as if putting out lots of volume but in reality very little air from the window & side demisters. When switch put on floor/defrost more air comes from the defrost outlet then on defrost alone. Took it to the dealer & the tech compared it to another & said both the same so normal. Does your defroster do this also, called GM customer service & they said check with the dealer. Please check yours & reply.
Old Sep 12, 2001 | 08:21 AM
steve1173's Avatar
steve1173
Default Re: Defroster Help (steve1173)
Someone please check your defroster & reply so that when I return to the dealer if it is broken I can push the issue with them.
