Fuel Filter Replacement??
Old Jun 18, 2013 | 12:38 PM
jayvee01's Avatar
jayvee01
4th Gear
Thanks much for the info.
Very clear
Old Jun 18, 2013 | 02:42 PM
gun5l1ng3r's Avatar
gun5l1ng3r
I am very surprised that the 04 cars dont have a servicable fuel filter...
How high do you need to lift the car in order to drop a fuel tank?
Old Jun 18, 2013 | 06:49 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Since this thread is really old, and recently revived, I'll just throw in an "FYI"....
My car is an '01, with low mileage (22K). I changed the OE filter when the car was about 4 years old, "just because". In other words, preventive maintenance.
Last summer (2012), I started smelling gas after the car was shut down. Then one day, while driving, I smelled it again. Although I didn't originally see any drips, as soon as I got home from my drive, I ran the car up on the ramps and started looking. I noticed the filter outlet side was dripping. Apparently, the ethanol content of the gas had attacked the o-ring on the filter, as simply replacing the filter cured the problem. Good thing, as the fuel line runs right over the LH side exhaust pipe....
Old Jun 18, 2013 | 06:55 PM
Caveboy's Avatar
Caveboy
Is it really that bad to replace to ne on a 99 auto?
Old Jun 18, 2013 | 07:07 PM
leadfoot4's Avatar
leadfoot4
Shouldn't be. It IS awkward, especially if you're on ramps, and not on a lift, but not impossible...
Old Jun 19, 2013 | 02:16 AM
YellowFlash's Avatar
YellowFlash
CI 7 & 9 Veteran
Default Replace as needed
My previous '01 C5 had over 200,000 miles on it and I never had to replace the fuel filter. Granted I always did use Chevron gas religiously which probably helped. I would recommend to replace it only if needed.
Old Jun 19, 2013 | 06:57 AM
leadfoot4's Avatar
leadfoot4
But did you ever consider, given the mileage, that the filter may have been partially plugged, due to minute debris, or even that the filter material itself had "broken down" over that length of time?
Just asking.....
Old Jun 19, 2013 | 12:19 PM
YellowFlash
CI 7 & 9 Veteran
Just asking.....
For sure, that's what filters are for; like oil filters. I was always wondering how long can it go without replacement, but I never had any service center tell me I had fuel pressure issues. The Vette never gave any codes indicating any fuel issues. The original fuel injectors were all still working. The only indication I had was a slight reduction in gas mileage from 23+ to 22 average mpg; but that could have been from aging engine parts too. So if the fuel filter is partially plugged but still working, why change it?
Could the Techron bottle treatments and Chevron gas be breaking down the minute debris and allowing it to get past the injectors and be burned in the combustion chambers?
