Steering problem
Old Sep 9, 2006 | 09:29 PM
Dippy's Avatar
Dippy
Cruising
Default Steering problem
My 2K vert wants to follow the groves in the highway when driving on the interstate highways. I didnt notice this until I had the front pully replaced which required removal of the power steering rack. I suspect this is an alignment problem, maby toe in. This gets a little unnerving at 75 80 mph. Any ideas?
Old Sep 9, 2006 | 11:32 PM
Bill Dearborn's Avatar
Bill Dearborn
Probably the shop reset your alignment within the spec but not at the same setting as before. Take it back and complain. Spec calls for a range of front toe that is almost centered at 0 degrees with a slight bias for toe out. I have mine set to the toe in side of the spec to keep the wander down.
Bill
