We've tried a couple of intakes and the vararam is still on top. We were looking back over the logs from our last drag outting and saw some interesting things. Most big H & C packages will start to lose manifold pressure at the top end of the RPM band well I can tell you its not the case with the Vararam. Our logs showed the manifold pressure MAXed out once we got to 2nd gear and up. Manifold pressure would flutter at the top of 1st and once you hit 2nd and the vehicle gets over 50mph the manifold pressure was pegged @ 101kpa. 3rd gear is the one that really shows, we usually shift @ 7800 in 3rd and manifold pressure was still pegged @ 101kpa at almost 8000 RPMs.
Phil
Not that I know if the vararam is any good, but I would argue your numbers are suspect.
If the max you always get is 101 kPa, your gauge doesnt seem to read accurate enough to me to say anything.
What was the Barometric pressure the days of the race? If it always says 101 kPa, then the atmospheric pressure isnt changing (it changes every day!) and your gauge doesnt see it.
Whats the difference between the barometric pressure, and the manifold pressure? I would argue that is the performance of the vararam.
The only advantage I can see is cool air coming into your car which we will all agree is better than hot air. If you take the Blackwing, cut the radiator shroud and then add the icebox I bet the results between the 2 are close.
I dont think he's using a gauge, he mentioned he noticed it in the logs so I'm assuming those readings are from the MAP sensor.
The MAP table peaks at 105 kPa. When I log a run/dyno of my blown vette it peggs out at 104 kPa. Not sure if 101 is the "max" for the particular MAP sensor has in that car but if it pegs there I would say it is maxed. The definitive way to tell that it is doing what it says is to log a run on the same car with another intake. I believe Vararam has done this and proved what Phil is saying.
Personally I believe it outperforms the other intakes at speed but the fit and finish are enough to make me want to ssteer away from it. We installed one on my buddy's '04 Z and were disappointed.
But if the vararam works, the difference between 50 mph and 100 mph should be a manifold pressure difference of around 0.7 kPa.
Since he doesnt show any decimals, and atmospheric pressure varies by at least that much. The data doesnt support any claim.
I ran one for 2 years, and I liked it, but pitched the old syle filter day one. My car trapped ok, and I was happy, but I changed out to another intake to try and get every bit out of my car. sighs...
My MPh are down, but I do not have a good base line to compare to. The car was trapping @ 123 in Fayetteville, in much better air with the vararam, and now 121 in not so good air. I have dropped .05 to .1 off my short time, and I am still running 11.4s:o
With soo many of them for sale now, I might buy a used one and throw it on for an good comparison. BLUFF I need every little bit I can, and for the $ and easy of the work, you can not beat the swap. More to follow...
Dave
We've tested different intakes @ the track and before:
Intake manifold pressure would start 100kpa and taper off to 96-97kpa at the big end when the motor uses more airflow.
Since we have changed we do not get the same drop off. This is also on a 346" motor that makes more rwhp than 98% of all 346" cars out there so the air demand is definitely going to test the intake.
I doubt that, we did the same test with a K & N and the dropoff on the top end was even worse. For a bolt on or small H & C car its not much of a difference.
Believe me I am not doubting your finding. obviously you have no reason to lie about what you are finding.
Here are my thoughts:
1. At the start and probably to the 1/8 (assuming you are not sitting on the line for some time) the vararam is probably not doing anything more than any aftermarket air intake.
2. After the 1/8 the vararam is sucking in cool air while most aftermarket is sucking in the hot air from the engine. that is an advantage, but if you cut the shroud and use the ice box on the blackwing then it should be doing the exact same thing.
3. There is only so much air that can make it through the air bridge so even if the vararam can bring in more air than the black wing it would be slowed down by the air bridge.
Right, and while I agree the bridge may be an issue, the filter pretty much knocks out any possibility of ram air effect. Airplanes pretty much have to switch an alternate air source that by passes the filter to get any kind of ram air advantage. Even then the induction tubing has to be pretty strait.
I don't think the temperature is different at speed for the other filters because the air is still in front of the engine. However I do think it is more turbulent than in front of the vararam, which might be the improvement the vararam folks are seeing.
All that being said, I plan on getting a vararam and there too many testimonials to question that it has something working for it.
Phil
Phil,
I saw your other post, glad to see you are getting that car dialed in for the Fall. Good luck with it. My 447 has a vararam on it and when running the quarter mile my car loves the top end and seems to be getting plenty of air. I have trapped just under 134 in good air. It would be interesting to take some readings to see if it is running out of air or not.
Phil
We need the Power of OT to keep this Vararam Mythbusters thread alive long enough to get noticed...
Phil, forget the naysayers... I belive you.. I have had the Vararam since they 1st came out...
It's NOT the cold air affect... It is the Velocity effect of the Vararam that is getting your MAP KPa up..
I wonder why people just wont accept that the world is Round no matter how many time it's proven..
I even posted on the Mythbusters site to PROVE it works...
I'm with ya. I don't care if people doubt or don't believe our tests, bottom line is how many 346" H & C cars will go 129mph @ almost 1900'. My results speak loud and clear.
Phil I went from the Breathless box to the Vararam last season and everything (performance wise) is much better with the Vararam. I am still using the Race Filter as my car is not a daily driver, which filter are you using? Also Patrick just sent me the New and Improved lid, wow what a difference.
