how do you remove stock steering wheel?
Old Sep 11, 2006 | 05:08 PM
BloodRayne's Avatar
BloodRayne
Default how do you remove stock steering wheel?
Im getting a custom one in soon and I hear they are a B!tch to remove...I hear that not only do you have to have a special steering wheel puller, the steering wheel has lock tight on it and its nearly impoossible to remove without stripping out the threads? Any suggestions or removal/install advice?
Old Sep 11, 2006 | 05:46 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Dealership.
Old Sep 11, 2006 | 06:58 PM
TEXHAWK0's Avatar
TEXHAWK0
You do need the right type of puller legs to pull the steering wheel, but I don't think the nut is installed with lock-tite.
The service manual does recommend that you replace the nut everytime it is removed, but I don't know of many (any?) people that do.
Old Sep 11, 2006 | 07:19 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
not a big deal; disarm the airbag, remove bolt, use the KD tool part #3510 J-hook pullers
read the shop manual on disarming the bag, it could cause serious injury and/or death
Old Sep 11, 2006 | 08:25 PM
BloodRayne's Avatar
BloodRayne
where do i buy these j-hook pullers?
Old Sep 11, 2006 | 09:25 PM
SteveDoten's Avatar
SteveDoten
http://www.toolking.com/productinfo....roductid=11600
call napa first
Old Sep 11, 2006 | 09:28 PM
SteveDoten's Avatar
SteveDoten
get the KD2291 that works w/ the hooks also, it's listed in the text
Old Sep 11, 2006 | 11:12 PM
Darkness's Avatar
Darkness
Stock steering is easy to take off. I took mine off without a puller actually. All you do is have someone put the knees under the steering wheel and put pressure up, then use both hands to pull on the upper part of the wheel and with the knees and hands pulling on the wheel, all you have to do is hit the steering shaft right in the center with a hammer and the wheel will pop right off.
I know its kinda bubba but works
Here's my wheel now.
Old Sep 12, 2006 | 10:08 AM
fixvet's Avatar
fixvet
I think the stock wheel is about the worst thing about my C5. I've never been comfortable with it.
I really like the Momo on your car. Where did you buy it?
Thanks...
Old Sep 12, 2006 | 10:39 AM
SteveDoten's Avatar
SteveDoten
I used to this when i worked at ALL Mustang in Phoenix, that was w/ the column out of the car without the steering shaft hooked up at the other end(besides they were just mustangs )
not sure on the details of the C5 column, but often there is a crush component in the system that could be damaged
Old Sep 12, 2006 | 03:15 PM
BloodRayne's Avatar
BloodRayne
I dont want to damage the stock wheel or the colum in any way...Ill try the pullers. thanx
Old Sep 12, 2006 | 04:27 PM
SteveDoten's Avatar
SteveDoten
is that a 50thAE w/ a black top? you did that?
Old Sep 12, 2006 | 05:22 PM
Darkness's Avatar
Darkness
Thanks...
Got it at a performance shop around here I think, but you can find some good ones on ebay or some online vendors.
Old Sep 12, 2006 | 05:23 PM
SynistrC5's Avatar
SynistrC5
I nearly feel out of my chair when I read that
Old Sep 12, 2006 | 07:08 PM
BloodRayne's Avatar
BloodRayne
Yep...I f-n love it too...I just got on photobucket so Ill have pics up in a few days...the rims are iforged 19-9.5 front and 20-11.5 rears
To how do you remove stock steering wheel?
