C5 Ground Issues...Again
Old Sep 12, 2006 | 03:07 AM
chasintn's Avatar
chasintn
Default C5 Ground Issues...Again
Okay, I have seen the diagrams of where the car grounds are located, but does anyone have actual pictures or detailed specs on how to get to all of the grounds? I need to clean all of mine thoroughly and put some dielectric grease on them to keep them from corroding again. Can you buy that grease at somewhere like AutoZone? Thanks for the help in advance. I have a 2000 C5 if it matters. The only grounds I know of are the one on top of each front tire well.
Charles
Old Sep 12, 2006 | 05:04 AM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
Charles
Post #15 (scroll down) has a picture diagram of all the ground points: http://forums.corvetteforum.com/showthread.php?t=896875
Good luck.
Old Sep 12, 2006 | 08:52 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Yes, you can pick up the dielectric grease at a local AutoZone
To C5 Ground Issues...Again
