Line Lock Brake Problem
Old Sep 12, 2006 | 06:25 AM
97Rob's Avatar
97Rob
Default Line Lock Brake Problem
Had a line lock installed on a 97 at the fire wall under the hood. The ABS is located in the rear of the car. Since the install the brake peddle is soft. First push goes nearly to the floor, then it tightens up. We have bleed the breaks 4-5 times, and there doesn't seem to be any air in the line. Thanks for your input.
Old Sep 12, 2006 | 07:44 AM
keanucosmo's Avatar
keanucosmo
If it is tied into ABS, you may have to have brakes bled with a Tech 2 scan tool.
Old Sep 12, 2006 | 08:48 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
It sounds more like a bad master cylinder.
The pedal should have the same amount of travel after each push if it was related to air in the lines.
Old Sep 12, 2006 | 10:42 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
It sounds to me like you have to bleed the ABS system. (Its different from bleeding the calipers) This is ONLY done with a Tech 2 or similar scanning tool.
Old Sep 12, 2006 | 03:23 PM
97Rob's Avatar
97Rob
I appreciate the input, and will pass it on. Thanks!
Rob Edwards
Old Sep 12, 2006 | 07:52 PM
97Rob's Avatar
97Rob
Back to the top for you guys that work late.
Old Sep 12, 2006 | 07:58 PM
chpmnsws6's Avatar
chpmnsws6
So would it be better to put the line lock after the ABS unit?
Old Nov 4, 2006 | 10:48 PM
cenman's Avatar
cenman
97Rob,
Did you ever get this issue resolved? If so, how? I just installed a line lock on my 98 today and I'm having the exact same issue? Thanks in advance.
Randy
Old Nov 6, 2006 | 11:28 AM
UVETTYA's Avatar
UVETTYA
I want to install a line lock so I hope you guys that have one will speak up.
Old Nov 6, 2006 | 11:47 AM
97C5ENVY's Avatar
97C5ENVY
I had the same issue after my line lock was installed. What i did to fix it was flush the entire brake system (front and back). I'd give that a try first before spending lots of $$$$.
Old Nov 6, 2006 | 02:04 PM
Jackal's Avatar
Jackal
Old Nov 6, 2006 | 10:08 PM
cenman's Avatar
cenman
Thanks for the suggestion 97C5ENVY. I'll try re-bleeding everything this weekend.
Old Nov 7, 2006 | 10:55 PM
Howard Wolf's Avatar
Howard Wolf
A little off the subject. I noticed your car on the trailer. Not sure if you haul it in this position but it looks like it's too far aft. Do you notice any excessive swaying at highway speed? Especially when a semi passes you? If so, moving it forward should help. I have a trailer like yours and position my C5 such that the rear view mirror is about 2-3 inches ahead of the centerline of the front axle. Works well for me.
To Line Lock Brake Problem
