Mini Tubs
Old Sep 12, 2006 | 07:41 PM
Twin Screws's Avatar
Twin Screws
Default Mini Tubs
Is it a waste of $$$ to tub your car to fit the larger tires?
Old Sep 12, 2006 | 10:16 PM
debmwb's Avatar
debmwb
If you like the looks...no. If you need the traction...no!
Old Sep 13, 2006 | 12:16 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
We mini-tubbed mine using LPE's kit. Nice, finished product. Well worth it.
Old Sep 13, 2006 | 04:06 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
depends on what you mean by larger tires, 335s will fit without tub, CCW and a few others make large enough wheels.
Old Sep 13, 2006 | 07:28 AM
supercoupe01's Avatar
supercoupe01
No regrets here. LPE's kit is very nice. 19 x 13's on the back really changed the look of the car. Especially from the back.
Old Sep 13, 2006 | 10:09 AM
Twin Screws
Default LPE Kit
Where did you have it done?
Old Sep 13, 2006 | 10:43 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
If you want to run 345/30/18 drs and cut 1.49 60's with tires inside the 1/4 panel lip........do it
If you want to run 345/35/18s and hug the twistys with tires inside the 1/4 panel lip....do it
I did, never go back
More info on my set-ups
http://temp.corvetteforum.net/c5/30s/index15.shtml
To Mini Tubs
