Accessory pigtail passenger side fuse??
Old Sep 12, 2006 | 11:40 PM
Phil97SVT's Avatar
Phil97SVT
Default Accessory pigtail passenger side fuse??
Is there a fuse for the accessory pigtail next to the fuse box on the passenger side? The ignition wire isn't working so I think the fuse is blown. Checked all the fuses and can't find one.
Old Sep 13, 2006 | 05:57 PM
tlove's Avatar
tlove
Bump, same problem here and checked every fuse.
Old Sep 14, 2006 | 12:00 AM
JC in XTC5's Avatar
JC in XTC5
The yellow wire I think you're referring to in the passenger footwell is the one that is taped for use for aftermarket accessories. It is powered off the ignition, and the associated fuse is 11 in that fuse panel. The orange wire in the bundle is powered off the battery (always live) and uses fuse 7.
If the fuse is fine, then check the connector for this wire bundle. The connector will have 3 wires: The Yellow and Orange noted above, and Black (Ground). It's possible that the connector came loose or the connector wires are open. The connector (C206) is supposed to be under the traction control switch in the center console according to the service manual.
To Accessory pigtail passenger side fuse??
