Please critique my H/C setup
Old Sep 13, 2006 | 10:03 PM
brians98ss's Avatar
brians98ss
Default Please critique my H/C setup
Please take a look at my proposed setup below. I think I'm close to putting the final touches together after months of deliberation/research and would appreciate some constructive feedback.
The car is a 98 SS that will see most of its life on the street, not the track. Since I'm in CA I have to take 91 octane fuel into consideration and smog (specifically the sniffer test). With that being said:
Heads: AFR 205s milled to 64 cc with .045 head gasket.
Cam: Comp 224 .581 lift 114 LSA
This cam I think is the largest that will pass smog here otherwise I would have gone for the 224/228. The cam will be installed on a 112 ICL which should put my DCR around 8.4 if my calculations are correct. Should be manageable on 91 octane.
Of course, the car will have full exhaust (LTs) and bolt-ons.
Well, what do you think?
Old Sep 17, 2006 | 11:33 AM
02redhawk's Avatar
02redhawk
4th Gear
It will be very stout, basically the same configuration as my Firehawk (224R, ported 243s milled .010", .045" HG, and all of the other boltons). Made 430rwhp/393rwtq on a Mustang Dyno. DCR is right at 8.4/8.5.
Old Sep 17, 2006 | 12:19 PM
99 vett babycar's Avatar
99 vett babycar
similar to my set up - check my sig - you should love it.
Old Sep 17, 2006 | 12:37 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
That's a good safe very fun street package. You'll love it
Old Sep 22, 2006 | 09:58 PM
brians98ss's Avatar
brians98ss
Thanks for the replies.
I hope it all works out.
Brian
Old Sep 22, 2006 | 10:00 PM
Honez's Avatar
Honez
It's a find setup, by the way I'm in So Cal and I see 224/228's pass all the time. Make sure your LSA is 114.
Old Sep 22, 2006 | 10:04 PM
SLPRC5's Avatar
SLPRC5
Yup I've heard that the LSA is the biggest part of passing the sniffer test. 114 or 115 are good ones.
To Please critique my H/C setup
