Center Console lid won't close...
Old Sep 14, 2006 | 09:08 AM
WildWolf's Avatar
WildWolf
Default Center Console lid won't close...
Tried to close it the other day and it just won't. It looks like everyting is OK but the part on the tranny tunnel won't accept the latch on the console. Anyone have any suggestions?
Thanks in advance.
Old Sep 14, 2006 | 09:19 AM
SouthernSon's Avatar
SouthernSon
I am not impressed with the engineering of the lid at all. The hinge seems to have to articulate somewhat to allow rotation. It is very tricky and prone to accept too much side load on the screws. You might check the screws of the hinge and carefully try slight pushing toward the passenger side as you gently fold it downward. Sort of like pushing against one's elbow with the opposite hand while bending your arm...(sorry, but its the best I could come up with as an example)
Old Sep 14, 2006 | 09:31 AM
TEXHAWK0's Avatar
TEXHAWK0
Put a drop of light machine oil on the hinge points. When I first got my car, I thought the lid would only open 2 or 3 inches until I oiled the hinges.
Old Sep 14, 2006 | 11:08 AM
rpm462's Avatar
rpm462
Check the part on the tunnel...mine ends up closed from time to time and I use a pocket knife to pop it back up so it will accept the latch from the lid.
Old Sep 14, 2006 | 11:11 AM
Oldvetter's Avatar
Oldvetter
This is the answer. There are many hinge pins, like 5, oil them all and you won't have any problems.
Old Sep 14, 2006 | 01:23 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default lid
when I bought my 2001 coupe used, the salesman indicated the lid would need replacing. i looked at it, popped the stationary latch up, and its been fine since.
Old Sep 14, 2006 | 04:08 PM
WildWolf's Avatar
WildWolf
I will try to pop up the latch.....I didn't know that was the correct position. It is down now I think. Can someone show me a picture of how it is suppossed to look? Thanks for all the responses.
Old Sep 14, 2006 | 05:48 PM
383LPE's Avatar
383LPE
Old Sep 18, 2006 | 12:21 PM
WildWolf's Avatar
WildWolf
how do u pop it back up? I tried with my key but no luck. Thanks again
Old Sep 18, 2006 | 06:51 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Old Sep 18, 2006 | 07:45 PM
WildWolf's Avatar
WildWolf
can someone please show me via picture or diagram. I don't want to break anything. i was taking a key and inserting it behind (towards the rear of the car) and trying to lift it forward (towards the front of the car) but it wouldn't budge.
Old Sep 18, 2006 | 08:57 PM
coupeguy2001
Default latch
don't have a pic, but I think it pivots on the rear of it
Old Apr 6, 2014 | 03:51 AM
Frank4202's Avatar
Frank4202
What did you end up doing to fix this? I have the same issue
Old Apr 6, 2014 | 05:28 AM
65GGvert's Avatar
65GGvert
Several guys are answering a question not asked. The problem is the latch, not the hinge. The part that holds it closed. Where the lock mechanism is.
Old Apr 10, 2014 | 12:42 AM
BrianAgar's Avatar
BrianAgar
I had the same problem. The latch wouldn't pop up or down and oil didn't help. I couldn't get mine to budge, so I simply bought a new one from Corvette Central and now it works great.
Old Apr 10, 2014 | 08:31 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default This may help
Also realize the original thread was from 2006, so hopefully he got his console to close!!!!!!
Old Apr 14, 2014 | 02:07 AM
SG Lou's Avatar
SG Lou
Originally Posted by alxltd1
Corvette center console c5 replace repair latch by froggy - YouTube
I'm glad this old thread came back to life...mine just broke. Catch assemble fell into the Console. At least now I know where to buy one !
To Center Console lid won't close...
Old Sep 25, 2015 | 11:17 AM
C5Guy2004's Avatar
C5Guy2004
2nd Gear
Default Hook was Backwards
[QUOTE=alxltd1;1586621879]
Thanks Froggy. I just replaced my amrest with a new cover and when I went to put the console back on I had the Hook portion on the lid facing the wrong direction and it would not latch. Your video helped me realize my mistake.
Old Jun 25, 2018 | 07:31 PM
C5YJ's Avatar
C5YJ
If you have a pick, like one of these:
https://www.homedepot.com/p/Husky-Pr...004H/204314893
You can slide the pick up between the carpet and the console to push the front detent. You can slide another pick into the slot above the lock cylinder to push the rear detent. With both detents pushed in, the latch mechanism can easily be pried up and out of the console.
After I did this, I found that my mechanism wasn't broken at all. It was stuck in the down position. Working at the bench, I was able to pry up the part that was stuck down. It now works perfectly, so I put it back in the car and saved myself a few bucks. Hope this helps anyone who has this issue! Thanks to everyone who posts here for the benefit of others.
Old Jun 26, 2018 | 10:57 AM
Fast one's Avatar
Fast one
It helps a lot to lube the internal parts of the latch with some silicone grease.
