Hissing sound?
Old Sep 14, 2006 | 10:07 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Default Hissing sound?
Just a couple of days ago it started to rain pretty heavy up in my neck of the woods and out of nowhere on start up a hissing sound was being made. I can't seem to pinpoint where it's coming from but it stops when I shut the car off and start it again or if I turn on the windshield defogger (WTF???). I removed the airbox on the weekend but it didn't make that noise then only when it started raining and not when it rained earlier on in the summer. Any suggestions. Thnx.
Old Sep 15, 2006 | 02:39 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Air pump? PCV hose? Check all your hoses.
Old Sep 15, 2006 | 04:13 PM
bob guzzy's Avatar
bob guzzy
Default hissing
check all the vacuume hoses, sometimes they crack, and in some cases suck shut, check pcv hoses also.
Old Sep 15, 2006 | 04:37 PM
mfrejek's Avatar
mfrejek
Snake!!
Old Sep 15, 2006 | 05:05 PM
themonk's Avatar
themonk
Originally Posted by mfrejek
Snake!!
"Snakes In A Corvette" I just might have something there, but seriously folks, checking the hoses is a good idea and could explain the sound but don't forget that the sound goes away if I restart the engine or turn on the defogger (and stays away after I turn the defogger off) so I isn't something that is constant. I doesn't get louder or higher in pitch if I rev the engine either, just a constant hiss. If you knew the history behind this car it might explain why I have so many minor problems with it.
Old Sep 15, 2006 | 07:42 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default hissssss
check your brake booster, usually if it leaks there, you can hear it.
if the defogger blows air, it's vacuum operated, and could be offsetting
or enhancing the sound you hear. have someone operate the car while you put your head under the dash. see if you can pinpoint a compromised vacuum hose or a cracked plastic diaphragm etc.
The temp change may be a factor just like wet weather changes crack the old distributor caps of yesteryear
Old Sep 15, 2006 | 07:46 PM
themonk's Avatar
themonk
I will try that, thanks.
To Hissing sound?
