Brake Pad Replacement??
Old Sep 15, 2006 | 09:52 AM
Nick1's Avatar
Nick1
Default Brake Pad Replacement??
Is it difficult, suggestions please. Any special tools required? Which are the best pads for all around street use and not too bad for brake dust? Thanks
Old Sep 15, 2006 | 09:59 AM
mark896's Avatar
mark896
I have AC Delco ceramic Durastops and they are grrrrreat. No dust, no squeal. As long as you don't track your car, I think they are the perfect application.
You don't need anything special for the swap. It took me longer to get jack the car up and get the wheel off then it did to swap the pads. For the front, just loosen the top bolt on the caliper and swing the caliper down. For the rears, you'll have to take out both bolts. But like I said, the job is easy.
Old Sep 15, 2006 | 10:04 AM
Nick1's Avatar
Nick1
Thanks Mark for the quick reply, that's what I hoped to hear!
Old Sep 15, 2006 | 10:30 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Z06 pads are great pads for stopping on the street. Ceramics will take longer to stop than OEM pads, but are nice because the dust is harder to see.
very easy. As stated for the front loosen the guide pin and swing the top down (It takes 1 wrench, I think a 16mm to hold the inside nut and a 15mm socket to turn the bolt or something like that). Now here is the trick.
Leaving the old pad in you can squeeze the bottom piston in with an plier wrench (big plier wrench). when you do this the top piston will pop out. So what you can do now is close the caliper so that the lower piston is on the rotor then just squeeze the the top piston (the lower cant push out because of the rotor) and you will now have enough clearance to put in the new pads.
It is really easy and we do it at the track in no time.
Just watch your reservoir brake fluid level. Dont want that over flow.
I would also suggest changing brake fluid if you are doing pads. Valvoline Synethinc Dot3/Dot4 is good for street.
The brake fluid can easily be changed using the Motive Brake Bleeder. It adds pressure to the reservoir thus allowing the brake fluid to flow easily when the bleeders are open (PM me if you want to know more about this).
Old Sep 17, 2006 | 09:56 AM
Nick1's Avatar
Nick1
You guys are great! Thanks!
Old Sep 17, 2006 | 12:05 PM
cadman's Avatar
cadman
Cruising
When I did mine, it was much easier to push the pistons in if I added a flexible tube on the bleeder and cracked the bleeder open. Additionally, the old fluid goes out the tube instead of back up toward the master cylinder. Don't let any air go back into the bleeder.
Old Sep 17, 2006 | 01:52 PM
nuke61's Avatar
nuke61
A way to make sure no air goes back up if you use the bleeder screw method is to put short tubing on the end of the screw and submerge it in a small jar of clean brake fluid.
Old Sep 17, 2006 | 08:19 PM
Oldvetter's Avatar
Oldvetter
I use these also.
Old Sep 17, 2006 | 08:24 PM
tsts's Avatar
tsts
What he said!
Old Sep 18, 2006 | 11:03 AM
bighank's Avatar
bighank
Default brake pads
Think the OEM pads stop better than the durastop ceramics. Went with them. More brake dust. More stopping power.
Do you want brakes to STOP or LOOK NICE? I also cleaned the calipers and put on the Dupli Color red caliper paint and topped off the Corvette logo with white paint. Takes a lil longer but the diffference in looks is dramatic. Have fun BIGHANK
Old Sep 18, 2006 | 11:28 AM
EStreeter's Avatar
EStreeter
I haven't done brakes but recently (last week) decided to paint the calipers which basically requires all the same steps except you have to remove both the top and bottom pins to move the calipers to a position them where you paint them without making a mess. As mentioned above a brake job would only require removing the top pin to swing the caliper out to get the new pads in. You can push the cylinders in while the calipers are still installed with a large C clamp or a wide jaw vise grip. Then just pull out the old pads and install the new and put the calipers back on.
If you old pads are worn and you have added brake fluid to the master cylinder, open it and remove some fluid so it doesn't over flow and make a mess when you press in the wheel cylinders.
Have fun.
Old Sep 19, 2006 | 08:48 PM
Nick1's Avatar
Nick1
Sounds good, I'm partial to the red and will do it again as on my previous Camaro.
Old Sep 19, 2006 | 09:09 PM
cruisemon's Avatar
cruisemon
I tried the Duplicolor red on my calipers and it promptly burned off from high temp (well, maybe it took 6 months ). What did I do wrong?
Charlie
Old Sep 20, 2006 | 10:53 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I agree w/ WW, the Z06 pads are good for the street: I had Hawks, they would stop like nothing else, but the dust was insane, lots of squealing
To Brake Pad Replacement??
