'Charge System Fault'
Old Sep 17, 2006 | 09:40 AM
Casem1's Avatar
Casem1
Default 'Charge System Fault'
Got that message yesterday as soon as I started the car. Drove it anyway with no problems. When I started it later, got the 'Service Tire Monitor Sys' and then 'Check Air Pressure' (hadn't started rolling yet) When I did roll all of the pressures came up. Finally, I checked the PCM and there are no codes at all. I haven't erased my H codes for about a month. Wouldn't one or all of these trip a code???
Car is a 99 with what I believe is the original alternator, but only 20k miles.
Old Sep 17, 2006 | 12:04 PM
debmwb's Avatar
debmwb
On the charge system fault -- not necessarily. It isn't uncommon to have a charge system fault show up now and again...you simply shut the car off and re-start.
